Speedo sticking
timbo.ambo
Speedo sticking
Post by timbo.ambo »
Hi all.
Recently my speedo has started playing up. When i accelerate it works fine. When i slow the car down the orange bar seems to be very slow in responding. Now when i stop the car, the orange bar seems to stay at 30….till i go faster.
I was thinking of pulling the instrument cluster and unscrewing the speedo cable and injecting some grease down into the cable - last time i looked, it was all greased up.
Or do you think this isn’t the problem. Maybe the issue in the speedo dial itself.
Has anyone had similar experience, and maybe a solution?
Thanks in advance
Tim (Grafton)
Re: Speedo sticking
Hey Tim
I suggest pull the Speedo out and dismantle. I had a similar issue and found my Speedo needed some TLC. Fine machine oil is best but you need very little.
I have a couple pics on my Ute page, see page 6 from below link. Whilst Speedo is out check the cable. If you apply grease avoid using too much at the top 1/4 of the cable as grease can migrate up to where you don’t want it.
viewtopic.php?t=17288&start=75
Re: Speedo sticking
Hi Tim , I had a similar problem with my 57 Chev, the speedos are similar and i was sent a very comprehensive servicing guide - it was so detailed anyone would think Harv had written it :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin:
Send me an email address and I will forward it to you.
Re: Speedo sticking
Thought I might as well print it out and post it in case anyone else wants it
Re: Speedo sticking
Re: Speedo sticking
Re: Speedo sticking
:thumbsup:
Re: Speedo sticking
Oh that's effing gold blacky! You the speedo whisperer.
