Red EK Seat Material
Fex
Post by Fex »
I caught up with a motor trimmer late last week. He has a bunch of old vinyl from a retired upholsterer. I got a small piece of some original FJ commercial material and a roll of brown material that will be close enough for my FJ army Ute. There was also a roll of what I think is red EK seat material if anyone is chasing it. There is 5m plus a little bit. Advised the price is $150/m if you take the lot. I don’t know much about trimming (like how they get the line and circle in the trim) but I’m assuming it is EK. The whole roll is as per the pic. Probably original material based on the chat I had. Happy to put you in touch or pick up and send if it helps. Location is Laidley, Qld.
Cheers, Andrew.
Re: Red EK Seat Material
That looks like the original EK insert pattern to me Andrew. If they had some of the iridescent in green or silver I would be all over it.
paging SunnyTim ...........
Fex
Post by Fex »
SunnyTim wrote: Tue Jan 25, 2022 7:05 am Thanks Blacky, Andrew you have done well to track down Rob's old stock it certainly didn't go to the dump then Image
Is it $150 per metre for 5 metres? When you weigh it up itthen needs to be press welded they become very expensive seat inserts.
Glad you scored then other material.
Tim
Sent from my SM-N976B using Tapatalk
Sadly more went to the dump than didn’t. About 2 minivans full. The trim I found at the dump shop was all that ended up there. The shop wasn’t too keen to help with the rest so it all went to refuse. The bloke kept a bit and there’s probably some gold in it but he doesn’t know what a fair bit of it is.
Cheers, Andrew
