Wanted Grey engine motor parts
admin_maintenance
Post by admin_maintenance »
Hi all,
I am converting my stock FJ sedan to 12 volt and require some grey motor parts. I have a narrow belt generator, so I require a narrow water pump pulley and a narrow belt harmonic balancer (Im pretty sure you can still get these balancers new - please correct me if I am wrong).
I am also after a 12 volt Bosch regulator.
Does anyone have these parts that they are willing to let go?
Thanks
Jason
Re: Wanted Grey engine motor parts
Rather than chase down the narrow-pulley hardware, and since you still have the wide-pulley originals, could I suggest a Lucas C45 generator instead? The C45 is a bolt-in replacement for the Bosch generator; the Holden pulley fits the Lucas generator, and you can use an (FB-EK) Lucas RB310 regulator.
If you want to go the narrow belt route I reckon I will have the bits you are chasing mate
May have something Jason. I can't remember what that generator came off. Grey stuff bit of a mystery to me.
admin_maintenance
all good, made contact with Blacky
