Clutch kit
Clutch kit
What’s the best heavy duty clutch kit for the manual stock box?
Mine is struggling with the enormous power of the Wray
Re: Clutch kit
Standard clutch is 200mm diameter driven plate. Stock 220mm red motor clutch should be ok or you could go 1 tonner spec. You should probably machine the flywheel if increasing diameter. Clearance to bell housing is the only other thing you need to watch. Mine appears to fit okay. It is on a red flywheel with grey crash box. I just got what ever brand they had on the shelf at reputable parts shop.
