6 inch fb rims
6 inch fb rims
hi all,
Has anyone got four or five 6 x 13 inch fb rims (for standard drum brake set up) for sale? Maybe moved to mags and have spares lying around?
Many thanks.
Re: 6 inch fb rims
Got some. 😀
Re: 6 inch fb rims
Well done Brett. Where'd you get them?
Re: 6 inch fb rims
Well, there are a set of 2 sixes and 2 sevens on ebay currently but I wanted all 6 inch. I ended up buying a set of 6inch jelly bean mags instead!
These will go on the warm grey motored EK ute (project 2) next year. For the (I swear I will finish it before xmas😀) sedan, I bought 5 cross plys to go original. I was hoping to put r80 13 tyres on sedan but getting steels made using my centres that fitted hubcaps was going to cost $1200 and the bands are imported from US and are currently not available anyway, meaning a long wait. So, going original made sense and keeps in context of my aim for this car. Fernando Yellow wheels here we come!
Re: 6 inch fb rims
Woah that’s crazy $1200! Anyway will look god with the crossplys and if you want to go tarmac rallying you will have the ute.
Re: 6 inch fb rims update
New tyres arrived yesterday. I didn't twig at the time, but they are radials that are similar dimension as the cross ply originals. I was thinking that they were cross ply tyres until they arrived yesterday.🥴 This is a perfect tyre to use for 4.5 inch original rims. $275 from Antique Tyres.
640/700SR13 Vredestein Sprint Classic Blackwall
"S" Speed Rated (112MPH)
Construction Tubeless Rayon/Steel Radial
Load Capacity 1202 lbs. @ 35 psi
Overall Diameter 24.70"
Tread Width 5.3"
Suggested Rim Width 4.5-5
Re: 6 inch fb rims
They sound perfect. Photos?
Re: 6 inch fb rims
Vredestein 640/700SR13 Sprint Classic
Re: 6 inch fb rims
And that's $275 each?
Given the choice between a more expensive, but correct profile tyre, or 185/70R13s from Nankang, well, it was hard to beat five for $450. And the added bonus is that I could wind the guys at the bike shop up and say that I can get tyres for my car cheaper than for my pushbike. Same goes for brake parts too . . .
Re: 6 inch fb rims
They look rather good Brett. Agree with Rob that they are rather pricey. Do the nankangs come in 185/80/13 Rob?
Re: 6 inch fb rims
I guess pricey is dependant on what you're trying to achieve. I wanted either 80 profile radials or original size cross ply because that is the modern size that matches the original car. I have already invested heavily restoring the original diff so tyres that fit the rim but not the engineering are not for me.
Re: 6 inch fb rims
Yep. Understood. And you've paid the money to get your original ratio diff restored.
My FC's diff had a leaking pinion oil seal, loose pinion flange, and munched-up pre-load shims. And I'd never found a 3.89 completely free from gear noise, so I binned it and for $100 slotted in a 3.36.
Clay - if Nankang offered a 185/80R13 I'd be very happy.
Re: 6 inch fb rims
just write a book Rob.
Re: 6 inch fb rims
They look like Bridgestone super cats to me. Reckon the nankangs are LT also?
Re: 6 inch fb rims
I guess the point of all this was centred on not being able to put 185 radials on 4.5 rims. For the ute with its non standard 6inch mags (or chromes) I have Sumitomo 185 r80 13 and very happy to have them. They just aren't an option unless you change rims. Hence the post which I'm now starting to regret😃 searching for wider rims that hubcaps fit.....
The tyres I posted are radials that fit 4.5 inch rims for those that are looking for that option. The first I have seen anywhere.
For everyone else with non standard rims there are quite a few options which we are all aware of I think.
