Maximum engine size for FB/EKs Holdens under NCOP
Many people have replaced the engine in their FB/EK with larger capacity motors. There are many arguments around just how big an engine can be squeezed into an FB/EK and still be legal. This thread aims to capture those arguments, so that the next bloke who wants to put a Merlin into his FB/EK has a good basis for the argument with the engineer :mrgreen:
Most, if not all states in Australia require that engine swaps be signed off by an engineer, and provide the National Code of Practice For Light Vehicle Construction and Modification (NCOP) as the guidance to follow. Some states have additional rules that the registration authorities have buried in their websites, or not published at all (for example, Victoria has a standard set of weights that often gets applied to vehicles). The arguments below are based off NCOP without reference to any additional rules an individual state may have.
NCOP can be found here:
https://www.infrastructure.gov.au/vehic ... _ncop.aspx
The part we are interested in is section LA Engine.
WARNING: NCOP is not a hard-and-fast set of rules. It is open to interpretation by each engineer. Some engineers are open to examining the rules, others are very rigid in their views. The arguments below are a good starting point, but are only here to help in the discussion with your engineer. You cannot force the engineer to accept the rules... only encourage them to view the rules your way.
Table LA1 of NCOP (bottom of Page 11) gives the recommended engine capacities. Note the use of the word "recommended"... the engineer has some choice here. NCOP does not state that engineer is limited to those values, nor can set lower ones... they are just guidance. For cars originally weighing more than 1100kg, NCOP allows:
Original mass (kg) x 5.0 = max. capacity in cc’s (for naturally aspirated cars), and
Original mass (kg) x 3.0 = max. capacity in cc’s (for turbocharged and supercharged cars).
The question then becomes: what does an FB/EK weigh? From NCOP Section 2.13.1 Vehicle Mass (page 12), the mass of the vehicle is
"the original (unmodified) tare mass of the model vehicle fitted with the largest engine available for the model in Australia but without optional accessories (air conditioning, tow bars etc.). The mass of the vehicle, whether it is a sedan, station wagon, utility, etc., should be based on the heaviest sedan version of the model (not station wagon version) sold in Australia".
We will need to convert between Tare weight and Kerb weight below. Tare weight is the weight of an empty vehicle with all of its fluids (oils, coolants) but with only 10 litres of fuel in the tank. Kerb weight is the same as Tare weight, but with a full tank of fuel.
Starting with FB Holden, the GMH publication "Holden Shop Manual "FB" Series (M32614) lists the estimated kerb weight of the heaviest sedan (FB/225) as 2494lbs (1131kg). The fuel tank capacity is listed as 9.5 imperial gallons (43.2L). To find the tare mass, we only need 10L of fuel in the car, and need to remove (43.2-10=) 33.2L of fuel from the kerb mass. Petrol density is not legislated in Australia, though typical values are 0.710-0.770 kg/L (taken from Shell information here: http://www.csinfosafe.com/CSIau/SDSIndex.aspx?flag=init). Choosing the lowest figure (0.710kg/L) means that the 33.2L of fuel weighs 23.6kg. The Tare mass of the FB thus becomes (1131-23.6) = 1107.4kg.
For EK Holdens, the GMH publication "Holden 'EK' Workshop Manual (M33099) lists the estimated kerb weight of the heaviest sedan (EK/225) as 2490lbs (1129kg). The fuel tank capacity is listed as 9.5 imperial gallons, the same as the FB. Using the same argument as the FB gives a tare mass of 1105.4kg. However, there is some leeway for the EK Holden. EK Holdens were fitted with a hydramatic transmission as an option. The hydramatic is heavier than the standard manual gearbox used in both FB and EK Holdens. Given the similarity in weights between FB and EK Holdens in the Workshop manuals, it is clear that the EK Holden weight is for a manual transmission. We can thus add some more weight to the Workshop Manual Tare mass to account for the automatic. The weight of the hydramatic gearbox is not given in the EK Holden workshop manual, but can be estimated from the Holden 'EJ' Workshop Manual (M35676) as the EJ Holden had a very similar hydramatic transmission. This Workshop Manual lists EJ Standard sedan with hydramatic as weighing 2567lb, whilst manual transmission cars weigh 2492lb (i.e. the automatic is 75lb heavier). The same weight difference applies in the values listed for Special sedans and stationwagons. We can thus add 75lb (34kg) to the EK Holden tare mass, giving an EK Holden a tare mass of (34+1105.4=) 1139.4kg.
In summary: Tare mass for FB Holden is estimated at 1107.4kg, and EK Holden 1139.4kg.
Going back to Table LA1 from NCOP:
FB Holden naturally aspirated maximum engine capacity = 1107.4 x 5 = 5537cc
FB Holden turbocharged or supercharged maximum engine capacity = 1107.4 x 3 = 3322cc
EK Holden naturally aspirated maximum engine capacity = 1139.4 x 5 = 5697cc
EK Holden turbocharged or supercharged maximum engine capacity = 1139.4 x 3 = 3418cc
Some capacities:
327 Chev at 5354cc is OK naturally aspirated in FB/EKs, but 350 Chev at 5732cc is not.
202 red motor at 3297cc is OK supercharged in FB/EKs, but the LN3 "Buick" V6 at 3791cc and the Alloytec at 3564cc are not.
Again, the argument above is not the only way to present the information to your engineer. It is presented here because the source of the information is able to be defended (e.g. uses original GMH published Tare masses). You can take information on weights from many other places. Each engineer may be more, or less accepting. There are plenty of 350 Chev EK Holdens, and blown LN3 FB Holdens out there.
Re: Maximum engine size for FB/EKs Holdens under NCOP
Very helpful Harv.
Good stuff Harv,
I wish I had of thought of this before the 327 went in. Oh well I'll have a chat to the engineer before I start the process.
BILLY BLACKARROW
Post by BILLY BLACKARROW »
I was told I could only go to a 308 so I went 305 Chev
BILLY BLACKARROW
A question on the Ozrodders site made me wonder a little. With all the NCOP engine limits, I had heard a legend that you could “engineer a car as a commercial vehicle with no engine constraints”. I had always thought it was a myth (or that someone was stretching the rules beyond their intent), but decided I would see if I could understand how it works. Forgive this long-winded post as I try to put down on paper the logic. It duplicates some info earlier in this thread, with apologies.
CAVEAT: At any stage of the argument below, an engineer can say “Naah, all good, you can have a much larger engine”. The story below is not about “my engineer will approve anything”… its more about “this is what the rules give as guidance to the engineer”.
National Code of Practice for Light Vehicle Construction and Modification (NCOP) Section LA Engine Section 2.13 Engine Capacity Table LA Recommended Maximum Engine Capacity sets engine constraints for vehicles. NCOP Section 2.13 Vehicle Mass says that the mass of the vehicle referred to in Tables LA1, LA2 and LA3 is the original (unmodified) tare mass of the model vehicle fitted with the largest engine available for the model in Australia but without optional accessories (air conditioning, tow bars etc.). The mass of the vehicle, whether it is a sedan, station wagon, utility, etc., should be based on the heaviest sedan version of the model sold in Australia. We saw in the post above that a defendable set of calculations gives:
NCOP Table LA outcomes.png (22.27 KiB) Viewed 8864 times
So where does the “commercial” bit come in?
NCOP Section 2.13 states that:
“Table LA1 does not apply to commercial (ADR Category NA and NB1) or four wheel drive off-road (ADR category MC) type vehicles such as commercial vans, light trucks, small buses, etc. for which there are no set recommended limits.”
Whilst FB/EKs were not 4WD vehicles, this sounds promising, as the early Holden utilities and panelvans were referred to as Holden as “commercial vehicles” in all their documentation (e.g. the workshop manuals described above). Unlike the other body shapes, utilities and panelvans also had maximum load plates riveted to the inner guard. Maybe this is enough to convince an engineer (“NCOP says commercials have no limits, and Holden called them commercials”). But maybe the engineer gets pedantic about “ADR Category NA and NB1”. So let’s dive a bit deeper into those Categories.
Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005 defines the ADR Categories. This Standard uses Gross Vehicle Mass (GVM). From the posts above we already have tare weight and kerb weight, now we just have to work out the GVM. We need to be a little careful here with the weights we use. When we were assessing within NCOP, we had to use the “the heaviest sedan version of the model” rule, even though we were applying to any of sedans, utes, wagons or vans. Now that we are checking a definition inside the Vehicle Standard, the “heaviest sedan version of the model” rule does not apply, and we need to use the individual weights for utes and vans.
GVM is defined as “the maximum laden mass of a motor vehicle as specified by the ‘Manufacturer’.”. It is equal to the kerb weight, plus the driver and passengers, plus the load (effectively everything that the car is designed to “push down on the road with”). For the early Holden commercials, the GVM was referred to as gross weight, and noted on a tag in the engine bay. The tags look like this:
Maximum gross weight plate.png (370.12 KiB) Viewed 8864 times
The information is also contained in the Commercial sales brochures released by GMH. The front cover and specifications page for FB commercials looks like this:
FB Holden commercial sales brochure first page.png (1.4 MiB) Viewed 8864 times
FB Holden commercial sales brochure specifications page.png (1.37 MiB) Viewed 8864 times
… and the front cover and specifications page for the EK commercials looks like this
EK Holden commercial sales brochure first page.png (2.05 MiB) Viewed 8864 times
EK Holden commercial sales brochure specifications page.png (1.38 MiB) Viewed 8864 times
From our early Holden engine bay tags and the commercial sales brochures:
FB Holden van GVM (gross weight): 1524.1kg (30cwts)
FB Holden ute GVM (gross weight): 1524.1kg (30cwts)
EK Holden van GVM (gross weight): 1651.1kg (32.5cwts)
EK Holden ute GVM (gross weight): 1625.7kg (32cwts)
We are also going to need the “unladen mass”. The Vehicle Standard defines this as “the mass of the vehicle in running order unoccupied and unladen with all fluid reservoirs filled to nominal capacity including fuel, and with all standard equipment.”. This is equivalent to the “kerb weight” given in the workshop manuals, though again we will need this number for both utes and vans, not just “the heaviest sedan version of the model”.
From the factory workshop manuals for our early Holdens:
FB Holden van unladen mass (kerb weight): 1160.7kg (2559lb)
FB Holden ute unladen mass (kerb weight): 1120.4kg (2470lb)
EK Holden van unladen mass (kerb weight): 1139.0kg (2511lb)
EK Holden ute unladen mass (kerb weight): 1112.2kg (2452lb)
Now that we have our GVM and unladen mass, what does the Vehicle Standard say that an ADR Category NA and NB1 commercial vehicle is? Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005 Section 5.7 says that an NB1 vehicle is 3.5 -4.5 tonnes gross vehicle mass. As we saw above, the GVM is not that heavy for our early Holden, so we cannot be an NB1 commercial vehicle. We will need to comply instead with Category NA.
Section 4.5.5. Light Goods Vehicle (NA) indicates an NA commercial vehicle is “A goods vehicle with a ‘Gross Vehicle Mass‘ not exceeding 3.5 tonnes.” We can meet the “GVM less than 3.5 tonnes” part easily from our GVM information above. Now we need to demonstrate our early Holden is a “goods vehicle”. Section 4.5 Good Vehicles says we need to be “A motor vehicle constructed primarily for the carriage of goods and having at least 4 wheels; or 3 wheels and a ‘Gross Vehicle Mass‘ exceeding 1.0 tonne”. FB/EKs have four wheels, (and a GVM greater than 1.0 tonne even if it had 3 wheels 😊). So far so good. The utes and vans are made to carry goods… so this may be enough to convince the engineer (we might again need to fall back here on Holden’s consistent use of the word “commercial” to show that the vehicle was constructed primarily for the carriage of goods).
If the engineer gets really pedantic, they could say that utes and vans were not made “primarily” for the carriage of goods – they were made primarily for the carriage of the general public, and the goods carrying was just a side-hustle. There is guidance under Section 4.5.2 that decides whether the vehicle is “primarily” a goods vehicle, or a side-hustle. Section 4.5.2 allows that “A vehicle constructed for both the carriage of persons and the carriage of goods shall be considered to be primarily for the carriage of goods if the number of seating positions times 68 kg is less than 50 percent of the difference between the ‘Gross Vehicle Mass‘ and the ‘Unladen Mass‘. Dammit… now I have to do some maths.
For our FB van,
a) The number of seating positions is three (bench seat).
b) The GVM is 1524.1kg.
c) The unladen mass is 1160.7kg
We have to show that:
“the number of seating positions times 68 kg is less than 50 percent of the difference between the ‘Gross Vehicle Mass‘ and the ‘Unladen Mass‘”, i.e.:
(3 x 68) < (0.5 x (1524.1-1160.7), i.e.:
204<181.7
This is not true, hence we cannot demonstrate that an FB van meets the definition of having been made primarily for the carriage of goods. We would need to use an argument that there are only 2 seating positions in an FB van. Then we get:
a) The number of seating positions is two.
“the number of seating positions times 68 kg is less than 50 percent of the difference between the ‘Gross Vehicle Mass‘ and the ‘Unladean Mass‘”, i.e.:
(2 x 68) < (0.5 x (1524.1-1160.7), i.e.:
136<181.7
This is true, and hence an FB van meets the definition of having been made primarily for the carriage of goods only if we accept that there are only two seating positions. Therefore an FB panelvan with two seating positions is a commercial Category NA vehicle as defined by Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005, and Table LA1 of the National Code of Practice for Light Vehicle Construction and Modification (NCOP) Section LA Engine does not apply (i.e. there are no set recommended limits for FB panelvan engine capacity).)
For our FB ute,
c) The unladen mass is 1120.4kg
(3 x 68) < (0.5 x (1524.1-1120.7), i.e.:
204<201.7
This is not true, hence we cannot demonstrate that an FB ute meets the definition of having been made primarily for the carriage of goods. We would need to use an argument that there are only 2 seating positions in an FB ute. Then we get:
c) The unladen mass is 1120.7kg
(2 x 68) < (0.5 x (1524.1-1120.7), i.e.:
136<201.7
This is true, and hence an FB ute meets the definition of having been made primarily for the carriage of goods only if we accept that there are only two seating positions. Therefore an FB utility with two seating positions is a commercial Category NA vehicle as defined by Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005, and Table LA1 of the National Code of Practice for Light Vehicle Construction and Modification (NCOP) Section LA Engine does not apply (i.e. there are no set recommended limits for FB utility engine capacity).)
For our EK van,
b) The GVM is 1651.1kg.
c) The unladen mass is 1139.0kg
(3 x 68) < (0.5 x (1651.1-1139.0), i.e.:
204<256.1
This is true, and hence an EK van meets the definition of having been made primarily for the carriage of goods. Therefore an EK panelvan is a commercial Category NA vehicle as defined by Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005, and Table LA1 of the National Code of Practice for Light Vehicle Construction and Modification (NCOP) Section LA Engine does not apply (i.e. there are no set recommended limits for EK panelvan engine capacity).
For our EK ute,
b) The GVM is 1625.7kg.
(3 x 68) < (0.5 x (1625.7-1112.2), i.e.:
204<256.8
This is true, and hence an EK ute meets the definition of having been made primarily for the carriage of goods. Therefore an EK utility is a commercial Category NA vehicle as defined by Vehicle Standard (Australian Design Rule – Definitions and Vehicle Categories) 2005, and Table LA1 of the National Code of Practice for Light Vehicle Construction and Modification (NCOP) Section LA Engine does not apply (i.e. there are no set recommended limits for EK utility engine capacity).
In summary:
NCOP provides engine guidance for modifying FB/EK Holdens. There is significant flexibility in what an engineer can approve. A defendable, NCOP compliant position for engine capacity is shown in the table below:
NCOP Table LA and commercial outcomes.png (30.57 KiB) Viewed 8864 times
HHHHHMMMMMMM- is it time to measure up the ute for a merlin conversion ???? :ebiggrin:
Blacky wrote: Sat Aug 30, 2025 11:04 pm HHHHHMMMMMMM- is it time to measure up the ute for a merlin conversion ???? :ebiggrin:
It's like your reading my mind...Grace's ute still has the motor in it with zero oil pressure.
This is (roughly) to scale:
merlin into an FB ute.jpg (29.74 KiB) Viewed 8839 times
Must...... resist..... temptation.... need..... to.... sell..... ute..... no.... more..... projects.... :lol:
Hi Harv,
Great write up and yes very interesting.
The only problem is that most engineers these days are quite educated with the rules and most wont budge or use interpretation unless you are very good at convincing them.
The quote here will stop most of the engineers in their tracks.
The mass of the vehicle referred to in Tables LA1, LA2 and LA3 is the original (unmodified) tare
(not station wagon version) sold in Australia.
Yes i know it says should, and that could be the lever for challenge. I have had a few experiences with engineers and it it is extrememly difficult to get them thinking out of the box.
I am watching with interest, as i know you will be asking an engineer the question.
I recall years ago Harko was building a ute with a big block in it on a Crown chassis and he swore black and blue it could be legally registered in NSW - he is not a good example though because to the best of my knowledge he has never actually finished anything he has started ..........
Blacky wrote: Mon Sep 01, 2025 11:21 am I recall years ago Harko was building a ute with a big block in it on a Crown chassis and he swore black and blue it could be legally registered in NSW - he is not a good example though because to the best of my knowledge he has never actually finished anything he has started ..........
From memory, Rod Hadfield had (has?) an EK van with a large-ish Chev in it. Can't remember if it is a 400 small block or a 454 big block. Rod's probably not a good example of compliance either.
Always wondered how this thing would have gone come engineering time:
https://www.fbekholden.com/forum/viewtopic.php?t=9259
Yeah Rods van has a big block in it - but it was built before there was any requirements for licencing I think - and as you say he seems to not have to play by the same rules as the rest of us , one of his hotrods has no front brakes !!!!
There are a few examples of big engined cars that would have no chance today.
One bloke from Blacktown, wont mention his name has 2 Escorts with V8 power 351's I believe. He was telling me that transport wrote to him asking him to surrender the regos a few years ago, he stuck to his guns and both cars still registered to him.
He told me once they go out of rego for any reason that will be it, they will never be registered again.
The point here is there will be someone from Transport looking at the engineering certificates and if it pushes the boundaries they will more than likely question the engineers.
The engineer I used for the wagon was picky, but I must admit he was reasonable for engine size. I could use the NCOP Table LA capacities, with no additional testing. If I wanted to go for a larger engine than that, then a beam test was required:
https://www.streetmachine.com.au/featur ... dified-car
At the time, a beam test was $4000. No idea what one would cost now. Looking at the article above, it looks like some simple steelwork to the hubs and a portapower/jack could do it, provided you were OK to dynabolt the assembly down to your floor (mebbe an old driveway, then grind the bolts off once you are done). No idea though if the CRS-type 3/4 chassis would pass the test, or if more bracing would be needed.
I believe a beam test in WA is about $3500 today
ya know how to find out ask an engineer :wink: i've asked numerous and they've all said it's a myth everything is based off a base model unmodified sedan, in NSW
of course if you fit an unmodified (unmodified not cut, not shortened not narrowed) the rules then apply to that chassis as that is then what the car becomes let's say as mentioned a crown chassis your say EK sedan will now be registered as a rebodied Toyota Crown
i've also spoken to a couple re engine size and forced induction one is a very strict engineer and both have said the same thing any size any induction AS LONG AS YOU DO AS WE SAY TO A "T"
