Water pump pulley
Water pump pulley
I have about a dozen of the bloody things but they are all big stud pattern . Anyone have an early style one kicking around ?
Re: Water pump pulley
Hey Blacky,
Don't have one but you could redrill it if it fits without hitting the harmonic pulley.
Go spend $5 at the local hardware and get a later pump. Oh hang on that was thirty years ago.
I had the same issue with my ute. Was easier to buy a new pump for about $25. You want the EH to HR, or maybe it is HD.
There is a couple on evil bay but not cheap - was just contemplating these pumps and has anyone noticed the now available pumps dont really fit the old pulleys? The old pulleys have 4 raised slots or strengthening ridges in the flange surface that sat in between the four prongs of the older model water pumps - but sit proud of the new and essentially mean they wont fit properly on any new pump - why would that have been neglected - surely would cause a bit of wobble innpulley ImageImage
62ekute
State: ACT
Post by 62ekute »
yep, I put washers (the same thickness as the ridges) between the two faces - so the bolts can do the clamping they are supposed to do
Hmmm but then you will be slightly out of line with other pulleys?
62ekute
State: ACT
Post by 62ekute »
you are only out of line as much as you would be with it sitting on the ridges...the thing is - everyone who has these new pumps is about 1mm out of alignment
62ekute
State: ACT
Post by 62ekute »
Blacky, I think this is what you are asking for...if you don't find one locally, or drill one out - give me a yell. Patrick
Grey motor pulley won't fit. It's an early red motor pump isn't it?
Yeah - its a new pump but I painted and installed the bastard without realising the hole centres are the early style :evil:
just go buy another water pump easier and probably cheaper than post for a pulley
