speedo drive
fraze
speedo drive
Post by fraze »
WTB> Speedo drive gear(the bit that screws into the side of the gearbox) Specifically need a 22 tooth unit from an FX - FJ gearbox. Hope someone can help. Fraze.
Re: speedo drive
What happened to the last one I sent you? :mrgreen:
fraze
Re: speedo drive
Post by fraze »
HI Harv. The speedo drive you kindly gave me is in my FC sedan. With my tyre size and 3:55.1 diff. it made my indicated speed pretty well spot on compared to my GPS.
I am just about finished with my FB ute resto. and as I am running the same tyre/diff. combination, a 22 tooth speedo drive should make my indicated speed close to actual. Cheers, Fraze
Re: speedo drive
Two early Holdens is a good problem to have :D
Sadly I don't have any more FX/FJ speedo gears left - the one in your FC is the last one I had.
