Moderators: reidy , Blacky
WesternWagon
Posts: 1035 Joined: Wed Jul 07, 2010 6:33 pm
Post
by WesternWagon » Thu Sep 12, 2019 8:54 pm
Finally bit the bullet and removed the bonnet of the sedan
It’s been one of those annoying things I’ve not been happy with since I bought the car
Different colour, poor prep under the paint and now I can see why it blistered.
The entire bonnet was skimmed with bog some of it coming off in big chunks, surface rust under it all. The blisters worsened over time. Highlights the importance proper prep.
Haven’t painted anything as big of a bonnet so should be fun. Another days rubbing first to remove all the bog before metal prep and epoxy.
Updates soon
Gazza
Member : Holden Car Club WA.
:ASRF Member
Posts: 13828 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Thu Sep 12, 2019 11:43 pm
4 inch or 6 inch brush Gaz ?????
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 8:49 am
8 inch roller
:ASRF Member
Posts: 2584 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Fri Sep 13, 2019 9:33 am
Deoxidine that surface rust Gaz,
Is the paint on the car acrylic ? Whist your at it drop the front a little !!
Posts: 2751 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Fri Sep 13, 2019 9:42 am
Careful Gaz we all know where these little refresh jobs end up
fb delivery
Posts: 1702 Joined: Sun Apr 25, 2010 10:17 pm
Post
by fb delivery » Fri Sep 13, 2019 9:47 am
I think the problem will be the old pink spray putty
and needs to be removed
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 10:43 am
fb delivery wrote: I think the problem will be the old pink spray putty
Yes I think so Rob bog over primer from what I’m told is not good practice, over epoxy is supposed to be fine.
Gazza
:ASRF Member
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 10:50 am
EK283 wrote: Deoxidine that surface rust Gaz,
Hi Greg
I’ll be using KBS rust blast as I have some in the shed. Put it on the wagon May years ago and it still holding.
Paint is acrylic it’s and acrylic is going back on as top coat, 408 epoxy then high build.
Drop spindles are on the bench with 3” lowering blocks
Gazza
:ASRF Member
fb delivery
Post
by fb delivery » Fri Sep 13, 2019 10:55 am
What we use is a one shot hi-fill primer
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 11:46 am
This is what I have in the shed
Looks a lot to paint a bonnet doesn’t include cutting compounds
Gazza
:ASRF Member
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 11:50 am
:ASRF Member
Posts: 11303 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Sep 13, 2019 12:34 pm
The Epotec 408 grey green. Got the same stuff and it doesn’t have as many nasties in it. Because the epoxy primer is non porous I suppose you can bog over it I don’t know.
So fb delivery says he uses a high fill etch. So would that be epoxy and therefore non porous? That’s what I like about the 2k epoxy.
WesternWagon
Post
by WesternWagon » Fri Sep 13, 2019 9:39 pm
Paint removal complete, KBS metal prep and ready for epoxy
It’s bloody ugly with all the big removed
going to test my hammer skills
Then bloody compressor shits it’s self
hire one from Bunnings then the bloody rain starts
Epoxy in the morning
:ASRF Member
WesternWagon
Post
by WesternWagon » Sat Sep 14, 2019 5:59 pm
Epoxy on that’s it until next break
Might look for a new bonnet
Hope the body shop fairies come while I’m at the pickle factory
Now this would be cool, doubt the fun police would see the cool side it
:ASRF Member
Posts: 1131 Joined: Mon Apr 26, 2010 2:08 pm
Post
by gpi » Sat Sep 14, 2019 6:08 pm
i love it.
oxy/acetlyene
