ignition barrel removel
BILLY BLACKARROW
Post by BILLY BLACKARROW »
I had an experience today with ignition barrel even though I had the key I couldn't get the barrel out what I found was the wire I was using to put in that little hole to compress the spring ,I was pushing it in to far and it wouldn't turn because the wire I was using would stop it turning hope that makes some sense and maybe help someone along the way :dohh: :dohh: I know they are tricky little suckers at best
BILLY BLACKARROW
Re: ignition barrel removel
Billy boy you're right on the money,
I had the same issue only weeks ago !!
