Moderators: reidy , Blacky
Its_Not_Pink
Posts: 11 Joined: Thu May 26, 2005 7:52 pm
Post
by Its_Not_Pink » Thu May 26, 2005 7:58 pm
Hi,
I've got some codes here that I need deciphered. Also can you get paint matched to code or is it better to get it colour matched. If you can get it to code does anyone know the mix code for the following paint codes.
TOP: 585-4585 I think this is barrier coral?
PAINT: 585-9700 " " pyramid coral?
TRIM: 777-969
INSERT: PO 478.A
Thanks
Posts: 3997 Joined: Wed May 11, 2005 2:19 pm
Post
by parisian62 » Fri May 27, 2005 7:21 am
G'day,
Yes 4585 is Barrier Coral and 9700 is Pyramid Coral. I would have thought if you doing minor touch ups a colour match would be OK but a total respray you would want the paint matched to code. Sorry don't know the paint codes or trim/insert names. Anyone else?
Stewart
gp
Posts: 36 Joined: Fri May 13, 2005 4:26 pm
Post
by gp » Fri May 27, 2005 7:59 am
G'day,
Trim 969 is Golden & Leonora Tan.
Hope this helps?
Graham
Its_Not_Pink
Post
by Its_Not_Pink » Fri May 27, 2005 5:14 pm
Thanks for the info it is much appreciated.
Gareth
CHO576
Posts: 96 Joined: Sat Jan 22, 2005 5:54 pm
Post
by CHO576 » Thu Jun 02, 2005 2:44 pm
GP,
Any ideas/thoughts on what Trim Code this might be:
TRIM code is: 666-820 ???
Also, you mentioned that TRIM: 777-969 ----- "Trim 969 is Golden & Leonora Tan", but what does the "777" portion of the code stand for?
cheers
J
Dr Terry
Posts: 232 Joined: Sat May 21, 2005 6:41 pm
Post
by Dr Terry » Sun Jun 05, 2005 12:38 pm
Hi J.
Check out the pm I sent you.
Dr Terry.
gp
Post
by gp » Tue Jun 07, 2005 7:36 am
Hi J,
Trim 820 is Mawson & Penguin Grey. Not sure of the significance of the prefixes?? Dr Terry could probably help here.
Graham
