EK wiper motor
EK wiper motor
Post by 138 »
I have just got hold of an EK wiper motor, and would like to bench test it , so I can work out the wiring for it. It has 2 spade terminals, and the earth strap. One would be the park terminal and the other power, correct? I am just trying to work out which is which before I hook it up to 12 volts and hopefully not let any smoke out.
Re: EK wiper motor
They normally have permanent power at the motor and are earthed through the wiper switch to make them go . I am not at home now so I cant check for you but hopefully someone will chime in and tell you which side is which - it may even be marked on the motor ?
Re: EK wiper motor
Should say BAT on the Bakelite adjacent one terminal. Other terminal to earth via switch. Earth strap provides park.
Re: EK wiper motor
Post by 138 »
Got it, Thanks all! Tried it out , one terminal +12volts (park), earth on the strap, and the other terminal earthed via the switch, all good.
