Dizzy gear oil squirter design change
I am getting closer to commencing the machining work on my meth monster project. The next step is to get the block bored out and sleeved, which will mean having to choose a block (I am fortunate to have a couple to choose from). The question is, which block to choose?
According to legend, the later blocks are the better choice as they have had less time to internally corrode than the early blocks. Probably made sense in 1970, but after fifty years I'm figuring even the later blocks will have corroded a fair bit. I reckon that by now the date of casting has way less impact on corrosion, and the main issue limiting corrosion would be how the block was used or stored. Block usage/storage is a crap-shoot - no way of knowing how most blocks have been treated over the last half century.
One thing that does stand out though is that at some stage GMH made a change to the oiling design. The earlier blocks had no oil directed to the area where the dizzy and cam gears mesh. This can lead to dizzy gear wear. Apparently GMH began casting (perhaps drilling) a hole in the cam bearing supply that directed oil to the area. I figure it would be a good feature to have, though apparently it is able to be done to earlier blocks by drilling a fine hole.
Does anyone know when GMH started this change to the grey motor oiling?
Are there any records (Accelerator, Service Bulletin, Workshop Manual etc) that documents the change?
How do you tell if the change was made to a given block?
How is the DIY version done - hole size, location, angle?
Re: Dizzy gear oil squirter design change
Harv,
The J blocks have this small-diameter hole (drilled into the oil gallery, by the way, as the oil pump and dizzy drive sit between two cam bearings).
A first guess at when this change was made would be at the same time as the grease cup on the distributor was deleted (and that'd be EK introduction?). The EK and EJ distributors have a flat machined onto the lower part of the body, an oil hole and what looks like a felt insert, all to allow engine oil to lubricate the shaft.
There was a magazine in maybe 2010 which ran a story on Des West's ATCC Humpy. I remember a photo of the motor which showed a small pipe to run oil to the distributor driven gear.
ardiesse wrote: Mon Dec 17, 2018 10:22 amThere was a magazine in maybe 2010 which ran a story on Des West's ATCC Humpy. I remember a photo of the motor which showed a small pipe to run oil to the distributor driven gear.
I picked up a similar modification mentioned in a grey motor writeup done by Ray Bell. Apparently the "external pipe" mod made by 50's humpy racers was taken up as a design change by GMH.
Harv,
I'm getting ready to assemble a J-series motor (which has meant five days of kerosene-hands cleaning parts and fixing other people's mistakes), and this afternoon I took a squizz at the oil hole for distributor drive gear lubrication -
1/16" dia, straight down to intersect with the oil gallery centreline, almost but not quite half-way between nos. 5 and 6 cylinders (maybe 1/16" forward of half-way).
Thanks Rob.
Feedback from the EJ/EH forum shows that the squirter change was advertised from August 1961:
http://www.ejehforum.com/viewtopic.php?f=4&t=11807
Perhaps a few of the EKs got the squirter. Be interesting to check late EK blocks.
Cher’s,
Craig Allardyce
Post by Craig Allardyce »
My EK has one Harv.
