FB boot seal
Posted: Fri Mar 02, 2018 3:58 pm
by 59wagon
Hi All, my boot seal is pretty much cactus. I can get one from Rares - anyone know if they fit ok?
Also, what’s the best goo to use to stick it in place?
It looks like the old one will come out pretty easy using a flat blade screwdriver.
The job looks pretty straight forward - any tips would be appreciated.
John
Re: FB boot seal
Posted: Fri Mar 02, 2018 4:00 pm
by 59wagon
Here’s a picture
Re: FB boot seal
Posted: Fri Mar 02, 2018 6:21 pm
by CHOPPED
sika flex is best by far
let me know if you need some mate
Re: FB boot seal
Posted: Fri Mar 02, 2018 6:38 pm
by EK283
Poke with caution John,
The dreaded rust normally lurks behind !!
Re: FB boot seal
Posted: Fri Mar 02, 2018 6:50 pm
by 59wagon
CHOPPED wrote: Fri Mar 02, 2018 6:21 pm sika flex is best by far
Thanks Paul, see you at the meeting tonight?
"Poke with caution John,
Regards Greg"
Good tip, thanks Greg. There's a few dings and dents I'll have to fix as well, the metal looks pretty thin around this area.
Re: FB boot seal
Posted: Sat Mar 03, 2018 12:00 am
Contact same as what Harv is using for head lining. They can be very tight like doors and sometimes the outer edge will pop out of the gap between body and lid. Pretty hard to get right at the top corners where water can pool and leak in.
Good luck
Re: FB boot seal
Posted: Sat Mar 03, 2018 7:15 am
I've used contact cement (Kwikgrip, gorilla snot) on the boot rubber with mixed success. Because it flexes frequently, the glue tends to come away. Sikaflex is a bit more long lasting.
Don't forget that the orientation of the rubber is important - the lip should point inwards towards the centre of the boot, not outwards.
Re: FB boot seal
Posted: Sat Mar 03, 2018 5:38 pm
by 59wagon
Harv wrote: Sat Mar 03, 2018 7:15 am I've used contact cement (Kwikgrip, gorilla snot) on the boot rubber with mixed success. Because it flexes frequently, the glue tends to come away. Sikaflex is a bit more long lasting.
Thanks, Harv. Which Sikaflex product? Here's the list from the big green shed:
https://www.bunnings.com.au/search/prod ... ctFrom=Any
In the picture below, you're saying the right hand side points towards the centre of the boot?
https://www.rarespares.net.au/welshpool ... ct=RBS1002
John
Re: FB boot seal
Posted: Sun Mar 04, 2018 7:11 am
59wagon wrote: Sat Mar 03, 2018 5:38 pmThanks, Harv. Which Sikaflex product? Here's the list from the big green shed:
I tend to use Sikaflex 257 or 252 from SuperCheap - more adhesive than a sealant.
59wagon wrote: Sat Mar 03, 2018 5:38 pm In the picture below, you're saying the right hand side points towards the centre of the boot?
Yep 8)
Re: FB boot seal
Posted: Sun Mar 04, 2018 10:04 am
by 59wagon
:thumbsup: Thanks Harv
