FB boot seal
59wagon
FB boot seal
Post by 59wagon »
Hi All, my boot seal is pretty much cactus. I can get one from Rares - anyone know if they fit ok?
Also, what’s the best goo to use to stick it in place?
It looks like the old one will come out pretty easy using a flat blade screwdriver.
The job looks pretty straight forward - any tips would be appreciated.
John
59wagon
Re: FB boot seal
Post by 59wagon »
Here’s a picture
CHOPPED
Re: FB boot seal
Post by CHOPPED »
sika flex is best by far
let me know if you need some mate
HEY IT WASNT ME
Re: FB boot seal
Poke with caution John,
The dreaded rust normally lurks behind !!
59wagon
Re: FB boot seal
Post by 59wagon »
CHOPPED wrote: Fri Mar 02, 2018 6:21 pm sika flex is best by far
Thanks Paul, see you at the meeting tonight?
"Poke with caution John,
Regards Greg"
Good tip, thanks Greg. There's a few dings and dents I'll have to fix as well, the metal looks pretty thin around this area.
Re: FB boot seal
Contact same as what Harv is using for head lining. They can be very tight like doors and sometimes the outer edge will pop out of the gap between body and lid. Pretty hard to get right at the top corners where water can pool and leak in.
Good luck
Re: FB boot seal
I've used contact cement (Kwikgrip, gorilla snot) on the boot rubber with mixed success. Because it flexes frequently, the glue tends to come away. Sikaflex is a bit more long lasting.
Don't forget that the orientation of the rubber is important - the lip should point inwards towards the centre of the boot, not outwards.
59wagon
Re: FB boot seal
Post by 59wagon »
Harv wrote: Sat Mar 03, 2018 7:15 am I've used contact cement (Kwikgrip, gorilla snot) on the boot rubber with mixed success. Because it flexes frequently, the glue tends to come away. Sikaflex is a bit more long lasting.
Thanks, Harv. Which Sikaflex product? Here's the list from the big green shed:
https://www.bunnings.com.au/search/prod ... ctFrom=Any
In the picture below, you're saying the right hand side points towards the centre of the boot?
https://www.rarespares.net.au/welshpool ... ct=RBS1002
John
Re: FB boot seal
59wagon wrote: Sat Mar 03, 2018 5:38 pmThanks, Harv. Which Sikaflex product? Here's the list from the big green shed:
I tend to use Sikaflex 257 or 252 from SuperCheap - more adhesive than a sealant.
59wagon wrote: Sat Mar 03, 2018 5:38 pm In the picture below, you're saying the right hand side points towards the centre of the boot?
Yep 8)
59wagon
Re: FB boot seal
Post by 59wagon »
:thumbsup: Thanks Harv
