Blue Six induction
Blue Six induction
Possibly not the ideal place to discuss this but here goes. Been looking for a carb setup to suit the twelve port Holden straight six manifold to run in my van for a while. The only options beside the factory varajet set up seem to be Holley two and four barrel or triple Webber which is pretty expensive.
Lately I've seen a twin zenith downdraft two barrel setup with included exhaust manifold. The price and flow seem about right but I know nothing about this setup. Just wondering if anyone on here has heard of this setup before.
Clay
Re: Blue Six induction
Carbys off XF era Foulcans are a pretty popular swap.
390 Holley - good breadth of performance from idle to WOT, excellent sizing for the larger GMH straight sixes:
http://www.fbekholden.com/forum/viewtop ... 390+holley
Thanks fellas
That is very impressive and makes sense based on the small primaries/vac secondaries. Always thought 4 barrel was over carling on a six but the anecdotes say otherwise. I think the 12 port 4 barrel manifolds are available.
Clay
Not much change out of $1.5k by throwing cash at EPAy.
Will see how the Varajet goes for a while. Picked up a spare with manifold for $20 or 30 the other day. I've always got around 22mpg in the EK with the 3.3 trimatic. Same as the strommie and 280 Holley on 186 4spd for that matter.
Another $500 gets triple webbers. I suppose they would be finicky to keep tuned and not as efficient on juice. Then there's filters, linkages.
Errol62 wrote: Thu Sep 14, 2017 2:16 pmWill see how the Varajet goes for a while. Picked up a spare with manifold for $20 or 30 the other day.
I've got a Varajet tuning kit (not overhaul, tuning - various jets etc) if you want to have a play :D
Thanks Harv
I might take you up on that when I get it in the car. I do like using factory setup where practical which is the main reason I went to the blue motor in the first place.
Clay
Ol_Girl_58
Post by Ol_Girl_58 »
Hey Clay,
I know you're asking about carb options for your blue six, but have you thought about EFI? Sonic Injection do some really cool stuff.
https://www.sonicinjection.com.au/index ... onversions
Regards,
Josh
P.S. I'm [slowly] piecing together a six throttle body sequential EFI 202 red motor.
Cheers Josh
Maybe one day. Meantime a smelly old carb will suffice. Wonder if you have seen Pete Mallaby's injected grey on the FC FE site. Well worth a look.
Clay
Ol_Girl_58
Errol62 wrote: Fri Sep 15, 2017 4:29 pmWonder if you have seen Pete Mallaby's injected grey on the FC FE site. Well worth a look.
Yes I have - Pete's an absolute magician and a nice bloke too; he's always been happy to answer all my dumb questions regarding setting up EFI. Good luck setting up your carb/s; I say go for triple webers :thumbsup:
Josh
Must admit it is tempting just from the wow factor. Seen a set on a local FB. They make his mates Holley look like a lump of sh!t metal.
Sonic lnjection do a manifold set for triple SUs to 12 port head.
https://www.sonicinjection.com.au/index ... -manifolds
They also list a nice sounding manifold for Holley 4150 series. Think these are mainly mechanical secondary 4 barrels?
Found a 390 Holley on gumtree $250 on a red motor manifold
Errol62 wrote: Thu Mar 01, 2018 10:20 am Found a 390 Holley on gumtree $250 on a red motor manifold
That's a bargain 8) 8) 8)
