EK front Tar babies
Rapps
EK front Tar babies
Post by Rapps »
Hello All !.
Has anyone done a instruction post on fitting a pair of front mud flaps to the FB EK ?
Thanks in advance Lindsay :ekholden:
Re: EK front Tar babies
Welcome to the forum mate :thumbsup: :thumbsup:
I cant help you with your question but I am sure one of the brains trust will have a copy of the fitting instructions on file.
Rapps
Post by Rapps »
Thanks for the welcome and I am sure someone will have that somewhere. I scrolled but no luck
There are some great and useful threads here as well . I'm glad to be part of it
WayneXG95
Post by WayneXG95 »
Lindsay
Which one's do you men - Mud Flaps or Tar Babies - both different things?
Wayne
Rapps
Post by Rapps »
Sorry been away from internet.
Looking for the instructions on the front rubber ones
WayneXG95
Post by WayneXG95 »
Do you live in Sydney?
G'day Rapps,
The front fender mud guards are common from FE to EK (part number 7406592). One way to get hold of the instructions is to log onto the FE/FC forum, and politely ask CustomFC (Alex) for a copy. Alex is a strong contributor to the FE/FC forum "Accessory of the Month" threads, and probably has a copy of the instructions you are after. He is also a damn good bloke to deal with, and has gotten me out of trouble a few times. Sadly, the threads are only accessible for FE/FC club members, though Alex may be able to help you out of a tough spot.
Rapps
Post by Rapps »
G'day Wayne and also Harv
Thanks for the info I will have a look there Harv
Wayne I live on the Mid north Coast near Kempsey
Thank you both Lindsay
WayneXG95
Post by WayneXG95 »
ok I was going to offer to look at mine :)
timbo.ambo
Post by timbo.ambo »
Hi Rapps
I know its been 9 months since you posted your question. did you end up getting hold of instructions? did you end up becoming an expert in mud flap install? I'm in the same situation now...looking to install the front flaps that go along under the front door - kinda. Any knowledge would be appreciated. eg: is there metal strip that goes with the flaps? and how far back from the bottom of the wheel arch do they recommend you place them?
maybe even a pic you could post on here.
Tim (Grafton NSW)
Rapps
Post by Rapps »
G'day Tim . yes I did
Jeramy Crupi in Vic makes the brackets and will have the instructions.
I made my own brackets but I think his would be better ,
Lindsay
timbo.ambo
Thanks for the info mate. I found Jeremy on the "FB EK Holden fans" facebook group. I'll message him
Still you should feel free to post a front mudflap pic here :thumbsup:
timbo.ambo
It was Sam Crupi - his dad. I'll give him a ring.
Thanks again
This thread came up in a Google search when I was fitting front mudflaps today. I purchased these from Efbee back in June. They appeared to have multiple sets of mounting hardware, some of which was manufacturer fitted.
I ended up discarding the fitted bits in favour of long one piece brackets which I assume are the Crupi items mentioned above. Everything required a degree of massaging but turned out well. Was a matter of alternately clamping, some redrilling, pop riveting and cutting off some excess bracket at the rear.ImageImageImageImageImageImage
Nice work Clay - I still have mine to fit at some point
