Turning Engine By Hand
rtelford
Post by rtelford »
Bit of a dumb question, but do any of you have any tips on turning the engine by hand to find the timing mark. I have been using a spanner on the front pulley, however there is not a lot of room in the engine bay so I can only turn a few degrees at a time. Any clever ideas to make this easier?
While I am at it, do you guys loosen the distributor clamp by getting under the car, there is not much room in the engine bay here either, is there an easy way?
Rod.
Re: Turning Engine By Hand
Should be able to turn the engine over by manipulating the fan.
The 1/2"AF bolt that locates the dizzy should be fairly easy to access from the top.
If the engine is well used usually I find by pushing down on the fan belt with one hand and turning the engine fan with the other does it. If your fan belt is really tight you might not need to push down on it as that just stops it slipping and you can use two hands on the fan.
fingers
Post by fingers »
Take ya plugs out if ya havent already .......
