Rear Door wiring
nes138
Rear Door wiring
Post by nes138 »
Hows everybody wiring up rear doors? I cant think of how to get around the bloody window channel into the pillar
Re: Rear Door wiring
do what I did - buy a ute :lol: :lol: :lol:
nes138
Post by nes138 »
Blacky wrote:do what I did - buy a ute :lol: :lol: :lol:
hahaha well it a bit late for that now then isn't it
Is the wiring for electric windows?
I would imagine going in near the bottom hinge.
Sent from my D5303 using Tapatalk
For the wagon, I ran wiring directly down the B-pillar. It is open at the top, so you can feed down a length of fine fencing wire. I drilled a hole in the pillar (above the hinge), and fed the fencing wire down. Made a hook from some more fencing wire, then fished through the hole until I caught the main fencing wire run. Pulled the fencing wire through the hole, then used it as a pull-through to run the cable back up the pillar.
For now, the hole is being used to mount a dome light switch. May become a spot to run wiring into the rear door in the future. It looks like I can drill another hole in the door at the same location. Run the wire through the two holes, and use a speaker wiring spring (~6" very light spring) to keep the slack wiring inside the door. Cover the wiring between the doors with a corrugated rubber tube length.
The issue is inside the door where the window channel runs.
nes138
Post by nes138 »
Trev wrote:Is the wiring for electric windows?
Central locking, power windows with option later of speaker and courtesy light from the Calais VT wiring.
nes138
Post by nes138 »
I'm thinking at the bottom inside of the glass with this...
nes138
Post by nes138 »
Nah stuff it. Did it anyway and works a treat.
Looks good.
nes138 wrote: Fri Sep 02, 2016 8:11 pm Nah stuff it. Did it anyway and works a treat.
how did you screw the nut on the end in the b pillar?
