Wagon tailgate - anyone know a friendly rigger?
With the panels all painted on the wagon, I need to pull my finger out and get them hung properly.
For the upper tailgate, I wasn't too happy with the original sliding locks. I replaced them a while back with gas struts. They took a bit of thinking to find the correct length to suit both the lift, and the retracted position (they kinda hide between the tailgate and body when retracted, so had to be careful with dimensions, especially diameter). The struts were made up by McNaughtans in Smithfield (97 Long St
Smithfield NSW 2164, telephone (02) 96095122), who stock various lengths and fittings, and gas them up to whatever load you are after. I used a spring balance to check how much load the struts needed to support, and then divided by two (as there are two struts). Gotta be careful to do this with the upper tailgate still installed, and measure where the struts will act (not at the end of the tailgate). My struts are gassed up enough that they come up slightly quicker than a new car bonnet, but not quick enough to deliver an uppercut to the unsuspecting.
I used the original mounting point on the tailgate, with a normal eyebolt end to the strut. There is a slight bending load on the strut, but probably not enough to damage it. In hindsight, I probably should replace it with a ball fitting (McNaughtans stock them):
On the body end of the strut, I again used the original mounting point. A spacer is required to bring the end of the strut away from the body (I used some stainless instrument tube offcuts):
For the lower tailgate stays, my intention was to use the original "rattly rods" to hold it open horizontally. I'm still not sure if I'll use them though. What I would like to try is some PVC-coated stainless steel cable, with an eye bound in each end. Provided it looks OK, this might prevent the rattling issue. The two cables would be about 2' long each (I'll measure for exact length), either clear or red coated PVC. Prefer thin cable - say roughly 100kg load rating each.
Anyone know a friendly rigger/balcony builder who could make these up from offcuts? If not, I'll start calling around the rigging supply and ships chandler places.
Re: Wagon tailgate - anyone know a friendly rigger?
Nice tidy mod Harv. Though I still like the original sliders which can be locked at half mast, aren't affected by dust like the struts and well and truly outlast them new fangled items. Best part of your mod is that the original items can easily be replaced back to original if desired.
Miami stainless on the goldy were good value when I did my balustrading a few years ago. Quoted them the lengths and fittings by phone. Delivered to me at a very reasonable price and perfect fit.
By the way, rattly bars on my van have rubber tube over lower halves, I believe from factory. Don't know how they got the tubes over the eyes or how effective they are.
Clay
Thanks Clay - appreciated.
Some Googling earlier in the week gave me a shortlist to call: Auslift (close to home), Sydney Lifting Equipment (Sydney Northern Beaches) and Miami Stainless. If I luck out with someone from the forum, I'll start calling around.
bootlegger
Post by bootlegger »
Harv I'm pretty sure Nepean Boltmaster does them to length.
Harv,
LB Wire Ropes at Girraween, 3 Amax ave do all that sort of stuff.
Thanks gents - appreciated.
I ended up getting some red PVC-coated wire strops made up by Bullivants - see page 7 of my build thread:
http://www.fbekholden.com/forum/viewtop ... 3&start=90
Bullivants normally do a lot of cranage, lifting and slinging inspection work, so I can be pretty confident that the strops will hold. They put a thimble eye into the end that mounts to the tailgate, which I have connected to the tailgate brackets with a stainless D-shackle (from BCF). The other end they left in a big loop, which fits under the normal mounting point for the rattling rods. The big loop lets the wire rope move, and prevents the aluminium crimps from contacting the paint.
Really impressed with the quality of the work that Bullivants did, based on a measurement and my dodgy description. Great blokes to work with, who went out of their way to make this work.
