Rotisserie Clearance Height
vmx-mxr
Post by vmx-mxr »
I know a lot of us on here would like a rotisserie rig to make life easy but wonder if it will fit in the shed as far as the height goes. I can most likely find a spot to 'spin' it but the ideal place is near the front of the garage where the panel door is.
Would a few out there with current shells in rotisseries or past experience with them, and the height restrictions post some info for me. I am sure others will be curious too.
I figure if I have to I will design around the height by dropping the base to gain some wriggle room but would prefer avoiding the extra work/time.
Thanks in advance.
Dave Mac
Re: Rotisserie Clearance Height
2350mm on the pannoImage
Floor clearance is 250mm
Sedan would be less of course
BS
Post by BS »
2270 on mine
It is jacked up about 660 off the floor though so I can rotate it around 360 without worrying about hitting any of the cross bracing. I could drop it down about another 400 if I needed but would need to jack it back up if I wanted to rotate it back level. As I am currently flipping it constantly between horizontal and vertical and I have the clearance I just leave it jacked up and only lower it if I am wheeling it anywhere
vmx-mxr
Post by vmx-mxr »
Thanks guys.
I measured 2200 but with some work I reckon I am going to be able to get a away with it.
Keep the figures coming in - this is handy info for lots of us !
Cheers.
Dave Mac :thumbsup:
