SLR torana
BILLY BLACKARROW
SLR torana
Post by BILLY BLACKARROW »
Can someone help with the wire colour's for the SLR Torana column I have put Torana column in my fb, I have done away with the ignition switch so don't need those just the left & right flasher & horn colour's I think? .
Also the Fuel sender, dose it have two wire's one being an earth.
BILLY :arrow:
Last edited by BILLY BLACKARROW on Sat Apr 02, 2016 2:00 pm, edited 1 time in total.
BILLY BLACKARROW
Re: SLR torrana
Same setup as mine Billy. You use everything on the column except the dark green and yellow wires.
Not sure on the gauge, but looks like separate wires.
BILLY BLACKARROW
Re: SLR torana
Why wouldn't you use the dark green and the yellow as I see it they go to the rear flashers / just asking as I don't wont to burn it to the ground at this stage.
BILLY :arrow:
BILLY BLACKARROW
Re: SLR torana
G'day Billy,
Apologies - I wired mine 15 years ago, and made a great wiring diagram. It then got a bath in rainwater, and is now illegible :oops: . My harness is packed up in a box and I would need to unpick it to see how I connected it to the Torana wiring (I can do that if needs be, but it will take time).
There are six wires coming out of the column in a flat ribbon:
a) yellow - I didn't use.
b) light green - I didn't use.
c) purple - used as power ex flasher can
d) dark green - I didn't use.
e) blue - used as rh turn signal
f) light blue - used as lh turn signal
g) black - used as earth.
