Loose Steering???
caz60b
Loose Steering???
Post by caz60b »
My FB has very loose steering....has sports steering wheel....if I put old steering wheel back on, would that help? or is there a more sinister problem going on in the steering???
Re: Loose Steering???
Check your steering gear for worn areas , they are adjustable to an extent - get someone to move the wheel from side to side while you get under it and look where there is slop - tighten/adjust sloppy bits as required.
caz60b
Post by caz60b »
Thanks Blacky, why are you not located in Port Hedland....Grrrr!!!!
If it is sloppy only on the straight ahead position then worn worm gear is the likely problem.
