Front end width required
Hey guys , could someone please measure a stock front end for me ? I need to know the wheel face to wheel face width , preferably in inches ........
Thanks in advance !!!
Craig Allardyce
Re: Front end width required
Post by Craig Allardyce »
inside or outside face Blacky?
Wheel mounting face on the drum please Craig , looking to buy a straight axle setup while I am in the US and need to know what width I need.
NoMAD
Post by NoMAD »
Blacky wrote:Wheel mounting face on the drum please Craig , looking to buy a straight axle setup while I am in the US and need to know what width I need.
YESSS! DO IT!
(bring back extra ones mate)
Nathan
Foundation Member
kelleigh54
Post by kelleigh54 »
Gooood Mooorning America ! OK Mr Black , have measured up Maggots EJ and I cant imagine anything different to FB / EK . Took measurement on the deck so as it is in a loaded state and measured between outer face of backing plates directly below king pin which is 1262mm and then backing plate to drum face with calipers is 76mm ( 3inch ) x2 =152mm being a total of 1414mm .The outer edge of drum is proud of the mounting face by about 1mm so pulling that away from both sides will be a grand total of 1412mm or 55.59 inches .Give me a shout when your back bloke as I need that workshop manual , have to rebuild the Quadrajet on the Statesman . Hate the bloody things , bits and pieces flying everywhere and then figuring where it all came from .
Thanks mate :ebiggrin: will drop it off in a couple of weeks when I get back - too busy having fun over here ATM :D :D :D
kelleigh54
:D :D :D Well that's obvious , you should be in bed at this time of the morning getting some beauty sleep ....... You need it :P
Harsh :cry: :cry:
....... But true :lol: :lol:
Craig Allardyce
Sorry Blacky, didn't realise its urgent. I wont be home from work till Sunday Arvo but can do it as the car is on the hoist whilst I'm doing the brake work.
Measured HR disc unladen 1405mm or 55 5/16". Measured EK drum unladen 1397mm which is 55" exactly. Measured EK rear 1420mm or 55 29/32".
Most cars of the era have slightly wider front track so looks like 55 1/2 - 56" would be the go.
No stress Craig 8)
