Manual v Auto
rickbantam
Manual v Auto
Post by rickbantam »
Hey gang,
Can you help a novice out! I've got an auto body EK Sedan its had a lot cut out of the front floor/trans tunnel I'm not sure if its had a V8 tranny hump put in or its factory! I've tried a number of requests for a donor car and have had no luck sooooooooo if I can find some kind Car fanatic on this forum to give me a picture of both a manual and an automatic body (front passenger area/transmission tunnel/lower firewall area) so I can compare with what I have. I also need to have a picture of the handbrake bracket (near the tunnel) so I have an idea as to what is missing. Thanks all the information on this website is sensational, I may well be after a tranny hump section depending on all of the information supplied
Todd
Ex Perth now leafy suburbs of Blackburn Vic
Re: Manual v Auto
Auto hump
oz_ek
Re: Manual v Auto
Post by oz_ek »
If you need floor sections / trans hump give 'earlyengineering' a call,(0410639656) he's not far from you and might have what you need.
Re: Manual v Auto
ManualImageImage
rickbantam
Re: Manual v Auto
Errol,
Thanks for the quick reply the more I look at it the more I think that my lower firewall is the original auto body type but I'll post a pick to see what you reckon
Todd
rickbantam
Re: Manual v Auto
Excuse the dodgy handbrake the original one has been hacked off!
Re: Manual v Auto
That has to be an auto floor Todd. Never owned one unfortunately but it looks factory and it's not a manual. The manual has a one piece cross member running the floor width with a slight hump to clear the crash box extension housing. The handbrake mechanism mount bridges under the hump effectively surrounding the extension housing. On the auto but missing from yours there is a brace running between the two inner subframe mounts on top of the floor. The manuals have a removable cover to enable access to the bell housing.
I would be looking for a hump from a rusted out donor. They don't generally rust. No one makes a factory replacement as far as I am aware. The donor would be an easy install and accommodates popular transmissions such as trimatic and Aussie 3 and 4 speed all syncro boxes as well as original gear.
Have fun with it.
Clay
Re: Manual v Auto
Auto floor it is or was !
rickbantam
Re: Manual v Auto
Clay,
Thanks mate for the info yep I had my wires completely crossed when I thought it was a welded in v8 firewall so glad that is sorted one massive headache has gone away, yep will put my feelers out on the forum for an auto hump
Todd
rickbantam
Re: Manual v Auto
Thanks Greg,
At least that has been sorted now to find the bits to fix it!!!
Todd
