Clutch replacement
graham
Clutch replacement
Post by graham »
looked on the net and decided to check Repco out about a clutch kit for a grey and they came up the best with a heavy duty kit (220ml) to fit a 149/179 that bolted straight in with no problems. Price at shop $170. Could have got a bit cheaper on the net but for the couple of dollars difference saved the hassles if something not right.
Graham
Re: Clutch replacement
Does that improve the gear change at all Graham or much the same?
I ask mainly as my dad did a clutch conversion on his 28 chev inline 4 to an early model commodore clutch which help immensely with the crash box but there was some flywheel machining required.
I guess the only benefit would be to be able to pick up first while moving - is that even possible?
Only by double de-clutching
