What to look for when buying?
WOTHA?
Post by WOTHA? »
Hi guys,
I am going to look at an EK thats supposed to be in great condition.
Apart from the normal, what sort of things am I looking for & what are the main rust spots?
Thanks in advance! :vecctor: :vecctor:
Re: What to look for when buying?
Depends a lot on what you want to use it for, and how much repair work you can do yourself (or are happy to pay others to do).
If you are looking for a daily driver, it's not a bad idea to find something with existing (not expired) rego. After more than half a century on the road, there is likely to be wear and tear in some unusual places. The registration authorities can be funny about what they will accept for new registration - many will not tolerate any form of rear main seal leak, some get funny about stuff as fiddly as torn seat covers. If you cannot do the work yourself, it is not unusual for the rego authorities to make demands amounting to $2000 of work to get an FB/EK out of a carport and onto the road. Having existing rego means you can do the work at your own pace.
Rust is present in any FB/EK... just better controlled (or hidden :x ) in some. Front (and to a lesser extent rear) floor pans, front subframe, boot floor, rear parcel shelf, front drain plenum, around the windshields, bottom of the front guards, bottoms of doors, sills.... plenty of places to find it. If you're handy with a welder, it's all repairable. If you're paying someone else to do it, you can rack up $5000 really quickly.
If you do not have registration, beware of anything that has had the grey motor swapped for a red motor in it. A common swap for decades, and historically acceptable to the rego authorities... until the last few years. If it has a red motor and rego, it is generally accepted as "grandfathered", and can continue to be registered. If it has a red and no rego, many authorities will want full engineering... think $2000-$5000 worth of changes and paperwork. The humble grey will take years of abuse, and run with almost no compression in it. As long a you don't mind adding some extra oil, they chug along for a long time. A motor that has been rebuilt in the last few years is a bonus... overhauling a grey will not give you much change from $1000-$3000, even if you are handy with the spanners. If it's only a weekend car, you can probably live with a half-knackered grey for quite a while.
The numbers above are pretty scary, and can make a $5000 bargain turn into a $20,000 moneypit pretty quick. If you want to end up with a showpony or have aspirations of a V8, add another $10,000 to that. If you're handy with a MIG, spanners and spray gun then you can do a lot yourself for less cash.
WayneXG95
Post by WayneXG95 »
As Harv said.
Work out a Budget then Double it.. :)
WOTHA?
Post by WOTHA? »
That's awesome advice thanks Harv. So basically they rust everywhere by the sounds of it, LOL!
Yup, the plan is for a SEMI-RELIABLE daily driver.
It's currently registered so I'll see how I go & keep you updated. :thumbsup:
WayneXG95
Post by WayneXG95 »
One of the threads I wanted to delete Stewart. :?
WayneXG95 wrote:One of the threads I wanted to delete Stewart. :?
It's still helpful as its a list of sorts, you just need to know what everything is. :mrgreen:
WOTHA?
Post by WOTHA? »
Anything helps at this stage.
Embarrassingly, The old cars I used to play with was the good old Morris Minor. :ughh: :crazy:
59wagon
Post by 59wagon »
WOTHA? wrote:Anything helps at this stage.
I wouldn't be embarrassed if my Morris looked like this (from the Ozrodders forum):
WOTHA?
Post by WOTHA? »
WOW! If mine looked like that I wouldn't be buying one of these!
I had a schmik windowless (2 seat) van & then kids came along. What do ya do?
iso007
Post by iso007 »
There is nothing wrong with an old morry.
kelleigh54
Post by kelleigh54 »
I would say that you have found a friend in Blacky !
WOTHA?
Post by WOTHA? »
Bloody missed it! Just couldn't get there fast enough. Oh well, the search continues!
