Hey guys, not to familiar with my Holden parts, this is a disc brake rear end for sale with other stuff, been shortened 20mm to fit an EJ so will probably fit an EK the same. Any ideas what it is out of, he said the front brakes are comode, so thinking a VN-VP. Is 20mm short enough to fit under an EK?. Trying to sort stuff for an EK V6 conversion, will update if and when the build occurs. Thanks for any input.
Disc Brake rear end
Disc Brake rear end
Disc brake rear end.docx- (69.16 KiB) Downloaded 118 times
FB Restomod V8 Sedan
Re: Disc Brake rear end
Welcome to the forum mate, it will fit but it depends on what offset wheels you want to run as to whether it will clear properly - and you will have to enter your car in the modified division at the nats
Chers Blacky, was thinking about buying Scoobbs, the missus couldn't see the value, especially after i said it would need another $10kish for paint & aircon, but that's one car i would enter the nats with.Blacky wrote:Welcome to the forum mate, it will fit but it depends on what offset wheels you want to run as to whether it will clear properly - and you will have to enter your car in the modified division at the nats![]()
