rocker cover studs
rocker cover studs
hey , if you are using a alloy rocker cover on a grey motor do you need to use longer studs ? cheer all
Re: rocker cover studs
Nope, they are the same length. Although I have seen 2 rocker covers that are a little bit taller. Show me a pciture and I'll let ya know.
no worries i,ll take a pic
Did you ever find out where you get the longer studs for the alloy rocker cover. I have the same problem and the studs are only just out of the holes and end up about half way onto the nuts.
