Doors / Window
Posted: Sun Feb 22, 2015 6:27 pm
by BILLY BLACKARROW
Ok it's time to put my doors back together has anyone replaced the rubber at the bottom of the windows and if so what did you use or am I being a bit over the top/keep in mind that it won't be driven in the rain unless I am cautgh out--- you may notice that I have the right gear for the job IE BEER
BILLY
Re: Doors / Window
Posted: Sun Feb 22, 2015 6:36 pm
by FBeing
Personally I'd replace it. Easy and cheap to do.
I got mine from Clark rubber. Can't remember the actual size 5 or 8mm?
Did the trick though.
Re: Doors / Window
Posted: Sun Feb 22, 2015 8:56 pm
by BIGREVNEV
sika flex
Re: Doors / Window
Posted: Tue Feb 24, 2015 7:39 pm
by BILLY BLACKARROW
I am in the clean /paint /protect stage -- but where do these 2 parts go I am sure they have to do with the windows but can't remember where
I am thinking they have to do with the back windows
And while I am on the subject is there a sequence to putting the glass back in the doors,
Thanks
BILLY
Re: Doors / Window
Posted: Tue Feb 24, 2015 10:25 pm
by bootlegger
I boughtbfrom spectrum channel setting rubber. You soak it in kero before you set the glass in. Somehow it holds into the channel better than normal rubber.
Re: Doors / Window
Posted: Wed Feb 25, 2015 12:02 am
bootlegger wrote:I boughtbfrom spectrum channel setting rubber. You soak it in kero before you set the glass in. Somehow it holds into the channel better than normal rubber.
That's what I used on my '57 , you put it all together looseish , then soak it with Kero and the setting rubber swells up and stays that way.
Re: Doors / Window
Posted: Wed Feb 25, 2015 9:03 am
by Trev
BILLY BLACKARROW wrote:I am in the clean /paint /protect stage -- but where do these 2 parts go I am sure they have to do with the windows but can't remember where
Thanks
BILLY
The are the window guides the screw on the inside front of your rear doors, the bailey rubber runs down them.
Re: Doors / Window
Posted: Tue Mar 03, 2015 1:13 pm
by BILLY BLACKARROW
SunnyTim
The windows aren't that clean
YET And the beer is very nice and cold
BILLY
