Doors / Window
BILLY BLACKARROW
Doors / Window
Post by BILLY BLACKARROW »
Ok it's time to put my doors back together has anyone replaced the rubber at the bottom of the windows and if so what did you use or am I being a bit over the top/keep in mind that it won't be driven in the rain unless I am cautgh out--- you may notice that I have the right gear for the job IE BEER
BILLY :arrow:
Last edited by BILLY BLACKARROW on Sun Feb 22, 2015 8:55 pm, edited 1 time in total.
BILLY BLACKARROW
FBeing
Re: Doors / Window
Post by FBeing »
Personally I'd replace it. Easy and cheap to do.
I got mine from Clark rubber. Can't remember the actual size 5 or 8mm?
Did the trick though.
BIGREVNEV
Re: Doors / Window
Post by BIGREVNEV »
sika flex :thumbsup:
BILLY BLACKARROW
Re: Doors / Window
I am in the clean /paint /protect stage -- but where do these 2 parts go I am sure they have to do with the windows but can't remember where
I am thinking they have to do with the back windows
And while I am on the subject is there a sequence to putting the glass back in the doors,
Thanks
BILLY :arrow:
BILLY BLACKARROW
bootlegger
Re: Doors / Window
Post by bootlegger »
I boughtbfrom spectrum channel setting rubber. You soak it in kero before you set the glass in. Somehow it holds into the channel better than normal rubber.
Re: Doors / Window
bootlegger wrote:I boughtbfrom spectrum channel setting rubber. You soak it in kero before you set the glass in. Somehow it holds into the channel better than normal rubber.
That's what I used on my '57 , you put it all together looseish , then soak it with Kero and the setting rubber swells up and stays that way.
Re: Doors / Window
BILLY BLACKARROW wrote:I am in the clean /paint /protect stage -- but where do these 2 parts go I am sure they have to do with the windows but can't remember where
Thanks
BILLY :arrow:
The are the window guides the screw on the inside front of your rear doors, the bailey rubber runs down them.
BILLY BLACKARROW
Re: Doors / Window
SunnyTim
The windows aren't that clean YET And the beer is very nice and cold
BILLY :arrow:
BILLY BLACKARROW
