Lj diff.
blackstack
Lj diff.
Post by blackstack »
Hi all,
I am looking at picking up a Borg Warner diff for my Ek. It has been modified to suit an Lj torana.
Housing,lsd and gears are brand new.
Can anyone tell me if this sounds pretty straight forward? Assuming that the width will be good as I believe that the Lj housing width is only about an inch or two narrower. Just a bit of welding for mounts I am guessing.
Grand plan is SCC front end and SBC, hopefully 327 if I can track down a good one.
Will be firing off numerous questions once the mods get underway. Love this forum!!
Andy.
Andy from Bangalow.
Re: Lj diff.
yep it's about an inch and half each side narrower knock the LC/LJ mounting hardware off weld suitable sadle plates back on sort out brakes and bobs ya uncle
blackstack
Re: Lj diff.
Cheers Mick.
Appreciate that.
Andy from Bangalow.
Re: Lj diff.
one thing i just thought of is if the diff is set up for discs you may have to check some distances
blackstack
Re: Lj diff.
Yes, its set up for commodore discs. Haven't got them yet.
Guessing the distances wont change a great deal though..?
Andy from Bangalow.
Re: Lj diff.
just clearance of callipers on the inner wheel well
Re: Lj diff.
If the diff is too narrow the calipers will hit the springs, I had a BW diff narrowed to Torana specs and the calipers cleared by a bees dick - it would pay to check before shelling out cash , if you convert it to drum you shouldn't have a drama.
blackstack
Re: Lj diff.
Gotcha. Cheers for that!
Andy from Bangalow.
EK JAY
Re: Lj diff.
Post by EK JAY »
EK JAY SINCE 1990
BIGREVNEV
Re: Lj diff.
Post by BIGREVNEV »
Brilliant Work
