engineer sunny coast
Beardz80
Post by Beardz80 »
Hi all just chasing an engineer around sunny coast, if anyone can recommend one would be great, im doing extensive mods to driveline, chassis and suspension, so anyone who can pass these kind off.,
Cheers Beardz80
Re: engineer sunny coast
Welcome to the forum mate, there is plenty of build threads on here that cover most engine swaps, what are your plans ?
Beardz80
Post by Beardz80 »
Hey mate, plans are sr20, c4 gearbox, vn diff, disc brakes all round and plenty of custom metal works
Well I am pretty sure that hasn't been done on here before, hopefully one of the guys local to you will chime in with a name of an engineer for you. What cubic capacity is an SR20 ????
Late 80's 2000cc all-alloy Nissan motor, 120-170 BHP.
Dr Terry
Post by Dr Terry »
The problem with an SR20 motor is that it produces its max power at over 6,000 rpm. Also unless you get the SR20DET you will be short on torque.
The solution is usually to use a low diff ratio (4.11 or similar), but you then need an overdrive type gearbox, so it remains drivable on highways.
When you say C4 gearbox, do you mean the Fraud 3-sp auto usually seen behind 302 V8s, or is there another type of C4, I've not heard of ?
Dr Terry
Dr Terry wrote:is there another type of C4, I've not heard of ?Dr Terry
Theres always the plastique type C4, the one that makes a loud banging noise. :lol:
Sorry, couldn't resist.
