Page 1 of 3
Slow EK rat.
Posted: Thu Dec 25, 2014 11:15 am
by makntracks
Hi all,
New to the forum and just picked up an ek sedan,
Will share pics and ask alot of questions along the way.
As usual i thought it was pretty straight, found lots of hidden surprises once i started to pull it down and have decided to bite the bullet and fix its once and for all.
So a pretty penny at rarespares later i should have all my repair section up in the new year and i can try and get the cancer sorted.
So far have. both sills, floor, rear quarters and bits of the inner sill. and 2 big holes at the B pillar and the bracing underneath them( have no idea how to do this???)
The plan is to remove all rust that i can find, will be taking most of it back to bare metal. KBS rust sealing everything and fishoil every nook and cranny once the repairs are completed,
Get it straightened out. give it a shot of satin black on the outside and a off white or lilac inside, and get the chrome gleaming..
Lower it a little and drive it... :coolllll:
Has stock rebuilt 138, all doors and gaurds are dint free so hopefully once the rust is sorted things it shouldnt be a major resto..
It is my first full build ive finished off a few projects in the parts but never one from start to finish so looking foward to it..
The start,
The move..
The wet season enclosure..
The rust......
The bit im worried about..
Any comments or help appreciated.
Im also in Darwin if any other members are up this way.
Re: Slow EK rat.
Posted: Thu Dec 25, 2014 7:35 pm
by Devilrod
Rust in all the usual places. Still not too bad. Mine was similar. Spend some time going through some of the build threads in members rides. It'll give you a good idea on how to tackle the repairs.
Re: Slow EK rat.
Posted: Fri Dec 26, 2014 11:46 am
by parisian62
Welcome to the Forum Mick. Everything is possible. Do one area at a time. Start with the pans. The underfloor bracing you might have to get some donor sections or new sections made up.
Stay with the Parisian Lilac...it's a great colour...but then I'm biased.
Stewart
Re: Slow EK rat.
Posted: Fri Dec 26, 2014 9:10 pm
by makntracks
Cheers for the comments.
Was thinking of doing the A pillar and sills 1 at a time first as the floor and its frame is pretty good apart from the B pillar base.
Inner sills are also looking good apart from a few little points.
The front subframe has been welded onto what is left of the A Pillar mount so just have to negotiate that tomorrow.
Also should the subframe just fall away once the 4 bolts have been removed or do the usually need a fair bit of persuasion.
Stewart, I Have spent the last few weeks reading your build over and over again, the workmanship and time yous put into it is first class if mine is half as good ill be happy.
I do like the lilac i might spray it on the inside..
Re: Slow EK rat.
Posted: Sat Dec 27, 2014 10:08 pm
by makntracks
Little more done today finally got front subframe off and started cleaning up the firewall getting all that 50 year old deadener off it.
Can any one decipher the plate for me and possibly give me a year model.
Re: Slow EK rat.
Posted: Sat Dec 27, 2014 11:23 pm
Its an Adelaide built car , and is Parisian Lilac , I cant read the tag well enough to see the trim numbers ????
Re: Slow EK rat.
Posted: Thu Jan 01, 2015 2:37 pm
by d1ll1g4f
Looks like 976 for the trim which is Armada Grey.
Re: Slow EK rat.
Posted: Fri Jan 02, 2015 11:15 am
by makntracks
Thanks for the replies, Was hoping it was lilac.
Waiting for Rares to get back to me with postage quotes on all my bits is killing me....
Been fixing the bits i can. Fuel tank out and started coating the boot in KBS rust seal. im going to do underbody and floors in it as well.
Few holes on the rear screen..
Re: Slow EK rat.
Posted: Fri Jan 02, 2015 4:11 pm
by WayneXG95
Brings back memories ay Stewart?
Re: Slow EK rat.
Posted: Thu Jan 08, 2015 9:46 pm
by ben
Welcome Mick....and well done taking on a tough job that WILL be worth all the effort in the end. Its not a great feeling finding more and more rust, but once you get a few new panels welded in you'll start to see that light at the end of the tunnel :thumbsup:
Re: Slow EK rat.
Posted: Fri Jan 09, 2015 8:51 am
by DOLLER60
G'day Mick- Good looking starter, a lot of blokes on here have started with worse!
Only advice I can give is lable everything in trays/bags from the cheap shop and keep chippin away!
Oh yeah and ask heaps of questions!!
Probably the best vehicle on this site was built in Darwin!
Re: Slow EK rat.
Posted: Fri Jan 09, 2015 11:55 am
by makntracks
thanks for the comments,
Bit of a monsoon up here at the moment so hard to get working on my days off.. all my panels from Rares are on there way so now hopefully things should start to progress a bit better.
Just picked up a nice period radio, so now have 3 but this one has a facia ect.. also some S type Jag overriders for the grill 8 all up with fresh chrome. :whistlinggg: :whistlinggg:
Started on the A pillar. just trying to keep it simple will probly run a crush tube through the middle tho just to keep it all together.
Decided im going to go with a Lilac/lace roof and satin black outside and Lilac inside, that way if i want it back to original colour its not a huge drama.
cheers
Re: Slow EK rat.
Posted: Fri Jan 09, 2015 4:10 pm
by makntracks
Little more done before back to work. Uncovered these littel spots while wire brushing the other day.. a lot more involved than i first thought..
Re: Slow EK rat.
Posted: Mon Jan 12, 2015 10:37 am
by DOLLER60
Do a bit of pigging mick??
Re: Slow EK rat.
Posted: Mon Jan 12, 2015 11:03 am
making good progress there mate :thumbsup:
