DIFF WIDTH COMPARISON
t337
Post by t337 »
This may be of interest wheel flange to flange
VB to VK sedan are 58.75inches = 1492.25 MM
VB to VK wagons are 59.75inches = 1511.3 MM
VN are 59.5inches = 1517.65 MM
EK 55.90" 1420 mm
HR 57.08" 1450 mm
HK 60.47" 1536 mm ?
HT/G 61.02" 1550 mm ?
LJ 53.93" 1370 mm
LH 56.69" 1440 mm
VN 1550 mm or 1560 mm ??
VY cross 8 4wd (12 03) 1706MM
1720MM with 7mm thick rotors attached.
XR-XY Falcon 59.05" 1500 mm
XA-EL 61.02" 1550 mm
XG van 11/93 1543 mm
EB 61.22" 1555 mm
BF 2004 falcon ute 1630 MM
740MM short axle, 835 long axle, 28 spline
mattathome
Re: DIFF WIDTH COMPARISON
Post by mattathome »
When you say wheel flange to wheel flange. Exactly what do you mean?
I'm having trouble with tyre touching the guards. Seeing how they are 185's was thinking my rig may have had a diff change at some stage..
MATT
Flange to flange refers to what the backing plates mount to on the diff. Or basically either end of the diff housing if it was bare.
mattathome
Thanks I will measure it ans see whats up...
I think the dimensions above are wheel flange to wheel flange which is the surface the inside of the rim sits on a complete rear axle assembly
Blacky wrote:I think the dimensions above are wheel flange to wheel flange which is the surface the inside of the rim sits on a complete rear axle assembly
Good point Blacky! I may have misinterpreted them.
there's a few there i'm a little suss on i've taken EK diffs out and put HR diffs in with wheels where i don't have half an inch to play with with no issues same with the differance between HK and HT/HG :? :think:
mattathome
Well just measured mine outside of drum to outside drum is 1425mm so very close to the eK measurements of 1420 so looks like my issue is the rims I have. It's proving hard to track down a set of rims... These ones came from a Ej Wagon but are 6 in rims. But after some reseRch looks like I have one hr rim with the whole. So back to square one.
Matt
Just pulled the EH rear out of my EK sedan. This originally came from an EH wagon but I believe the EJ EH were all the same drum to drum.
Here are some photos next to a stock EK axle. The widths are exactly the same.
I hope this helps someone.
Clay
i have said this many times but people always beg to differ :roll: :roll:
Just adding some info here as old mate John had me source him a UC Torana diff to chuck under one of his FBs. Image
It is the 8 bolt Salisbury 3:08 ratio. Big drum brakes which protrude around 8mm past the wheel boss.
Drum to drum 1460
Face to face 1444mm
Only 24mm wider than stock FB EK. I can kind of see why he wants to go this way but I don’t believe they are any stronger than a banjo.
