Honey pot clearance
kel3629
Honey pot clearance
Post by kel3629 »
Hi All
I have just reassembled my steering column but I do not have any clearance between the honey pot and the indicator assembly. Is there adjustment for this or have I stuffed up somewhere?
Kel
Craig Allardyce
Re: Honey pot clearance
Post by Craig Allardyce »
You need to pull the wheel off, remove the 3 bolts that hold the top bearing to the column, unscrew the bearing support a few full turns and reassemble it all and re-measure/check clearance.
kel3629
Post by kel3629 »
Thanks Craig
