Rear engine mounts (Hydra-Matic)
Dean&Jana
Post by Dean&Jana »
I'm having trouble finding a supplier for rear engine mounts for a Hydra-Matic grey motor original set-up. Rare Spares gave me the flick. Any ideas?
The FB-EK Holden Car Club of Queensland
Member Since 1993
Re: Rear engine mounts (Hydra-Matic)
Holden EK Auto Engine Mount Brackets Hydramatic Trimatic FE FC FB 7417859-60 New
gmhnasco (946)
100.0% positive feedback
Member since2010
Roger is reproducing them.
On eBay.
Dean&Jana
Post by Dean&Jana »
Thanks Trev, but I'm chasing the rubber/steel mounts themselves, not the brackets. I'm of the understanding that the Auto and Manual rear engine mounts are different. Although, to me, the rear mounts pictured on ebay and rare spares for manuals look very similar to the hydro ones I have removed.
Member Since 1993
Dean&Jana
Post by Dean&Jana »
Just looked up the Master Parts Catalogue and it does have Hydros with different rear mounts "insulator assembly' EK (H/T) 7417858, FE, FC, FB, EK (S/T) 4709885. So answered my own question (Tim was right as normal). Looks like it might be swap meets to find them.
Member Since 1993
Les
Post by Les »
From what I can find out the manual one will fit the auto http://www.rarespares.net.au/rarespares ... uct=EM1013
If you have any part enquiries or problems that cannot be solved by going to http://www.rarespares.net.au please contact me at lmcveigh@rarespares.net.au
Dean&Jana
Post by Dean&Jana »
thanks Les, they do look like hydro ones. I have some time up my sleeve as I'm chasing a drive plate/damper so it could be a while.
Member Since 1993
Les
Post by Les »
SunnyTim wrote:Deano EK manual wont fit. EK hydro same as all EJ ones
Sunny Tim
They may well fit but the are a different part number, if you are talking from experience then you my be correct I was using the GMH history which is not always correct.
If the EJ one fits then I will change our computer to reflect this.
Dean if you want to try one let me know your name and address and I will send you one free of charge if you fit it and let me know if it fits or not
Les
Sunny Tim
Les
That's mighty decent of you Les :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Blacky wrote:
Sunny Tim
Les
X2 :thumbsup:
