Hi FBEK'rs
Spent most today putting rear springs, axle and lowering blocks, about to install rear shocks.... now, does the robber bush go straight on the mounting plate post, because I have two different size metal bushings that seem to fit in the rubber bush (I am thinking these are for other models with smaller mounting posts, because they wont slide on to the FB post?
Cheers n Beers
Renno
REAR SHOCK INSTALL
REAR SHOCK INSTALL
- assembly.jpg (30.63 KiB) Viewed 870 times
- rear shock lower bush.jpg (22.13 KiB) Viewed 873 times
Re: REAR SHOCK INSTALL
Thanks Sunnytim
I will definately be at the next club meeting to say Gday (if your there) and get my membership
happening
Thanks
Renno
happening
Thanks
Renno
