Recently bought an EK manual waggon that goes O/K but struggles with a few people on board, I thought maybe I am expecting to much from an old grey.
Did a full tune with new plugs, leads, coil, points, and distributor cap and set timing but still no more power.
Got to thinking about the cylinder compression so did a compression test with the following results,
Cylinder 1 90 psi
No 2 90 psi
No 3 90 psi
No 4 80 psi
No 5 80 psi
No 6 90 psi.
The engine does not blow smoke or use oil but I was hoping someone more learned in this area could tell me if the reading are acceptable or low,
Thanks in advance,
Bibz.
