gearbox linkages
murray hewitt
gearbox linkages
Post by murray hewitt »
hi all ...are there bushes or nylon spacers to fit linkages to quieting gear change ? cheers muzz
Re: gearbox linkages
G'day Muzz,
It depends a lot on where the noise is coming from (gearbox, linkage, steering column) and when you are getting it (in neutral, moving into gears, moving out of gears, only in top etc). Give us some more detail on the noise and we can try to hunt it down for you.
This thread is not a bad pre-read though:
http://www.fbekholden.com/forum/viewtop ... 26&t=18606
Harv (deputy apprentice crashbox fiddler).
