Hi all can some one tell me the width of this spacer for the correct setup of the upper control arm I already have the lower spacer
I will be more then happy to make you a pair as well
Paul
Would I be correct in saying it's 20 mm wide and 35mm ID of the U
Upper control arm spacer tool 3A5
- Fishyweare
- Fishyweare
Re: Upper control arm spacer tool 3A5
Cheers for that cause that's what I ended up setting them at
Paul
Paul
