Lowered v6 ute
Mick.M
Lowered v6 ute
Post by Mick.M »
Hey guys, I thought I'd put some photos up of my ute for those that are interested. I've only been working on it for a couple of months and its progressing nicely. I have bought a vn commodore for a donor car, v6, 5 speed, will use diff etc. Heres some pics of whats been done so far. not sure if the photos will work?
Day 1
Because i'm bagging it i removed the front springs and found that it still sat 5" off the ground, so I decided to raise the front end 3" closer to the subframe by making new mounts
old mounts removed
Adding internal strength
New mount
Front and rear strengthening
Ends tapped around
Front and rear bracing
All welded
Fianl product, lowers the car by 3 inches
Comparison of before and after mounts, also single leafed with new mounts
After adding drop spindles it nows sits on the ground, onto the back
Plasma cut some new rails with 7 1/2" more kick up than factory, as I will be running a 28" tall rear tyre
spacers added
Extended to tie into the subframe for strengthening, no spacers yet
Plated top and bottom, 1/2" flange eiter side on the top for the factory look
Welds ground back
Cut the rear out and trial fitted
And this is how it currently sits, these wheels are only for mock up, will be getting steelies and whitewalls, currently in the process of stitching the rails in.
It's been a great learning curve as I've only just turned 18 and this is my first build, any feedback/advice is more than welcome. Thanks, hope the photos work for you.
Re: Lowered v6 ute
Cool as 8) 8) 8)
Welcome to the forum Mick, love how she looks sitting like that :thumbsup:
EKDV8
Re: Lowered v6 ute
Post by EKDV8 »
welcome to the forum mick :thumbsup: :thumbsup: :thumbsup: thats some radical work your doing to the ol girl ,keep the pics coming 8)
Re: Lowered v6 ute
Great fabrication work there Mick, welcome to the forum.
Re: Lowered v6 ute
WOW 8)
what part of NSW are you from looks like a small country town similar to where I am, but then they all look pretty similar
flamen
Re: Lowered v6 ute
Post by flamen »
Looks good :thumbsup:
Re: Lowered v6 ute
Wow.... :thumbsup: :thumbsup:
I can't believe how little rust is in the ute to start with either.
NoMAD
Re: Lowered v6 ute
Post by NoMAD »
man thats cool... be watching this one for sure.
:thumbsup:
Nathan
Foundation Member
Mick.M
Re: Lowered v6 ute
Post by Mick.M »
Mick wrote:WOW 8)
I'm on the Vic/NSW border in tocumwal
The rails were both rusted out but we were cutting them out anyway, there is a small amount in one guard and a bit behind the back bumper, both doors, bonnet and body are mint, and the patina and sunburn is in all the right places :D
hewey
Re: Lowered v6 ute
Post by hewey »
Looks great! Looking forward to watching this one progress :clap:
CHOPPED
Re: Lowered v6 ute
Post by CHOPPED »
awesome mate
your first build :shock: I look forward to seen more
don't paint it leave it as is
it will get more attention that way :thumbsup:
paul
HEY IT WASNT ME
Mick.M
Re: Lowered v6 ute
Post by Mick.M »
Thanks for all the feedback guys, Paint will definitely be staying as it is, only going to add some sign writing on the doors. Progress should pick up now that I've finished all of my yr 12 exams
Re: Lowered v6 ute
Clear coat it with a lattened clear should elp it last a lot longer!
Mick.M
Re: Lowered v6 ute
Post by Mick.M »
Got the rails mocked up in their final position, rear tyres are 275
cut and bent them so that they follow the same contour as the floor
this is where they tie into the subframe, will have bolts and a plate across the top so the subframe is still removable
we then took some measurements and cut the floor out
removed the inner sill, now we will sand blast in here, make new sills and will then be able to put the rails back in and start making crossmembers to tie the sills to the rails
also got the template made for the new windows
this is how its looking at the moment, completely stripped
and a quick picture of dads old EK that he built mid 80's, complete with shaved rear handles, FB grill and electric boot popper haha
thanks for looking guys
Re: Lowered v6 ute
My new favourite build thread - after Finny finishes his wagon that is :thumbsup: :thumbsup: :thumbsup: :thumbsup:
