ht rotors on hq stub axel and calipers
EK JAY
Post by EK JAY »
:econfused: Hi anyone know if you can use ht v8 rotors ( 15 .9mm width v6 are 11 i think)
on hq stub axels with hq PBR cast iron calipers
reason being i already have the hq stubs and calipers but want to keep the old holden bolt pattern
and ht rotors would do that .
any one done this combo :?:
EK JAY SINCE 1990
Re: ht rotors on hq stub axel and calipers
Pretty sure HG and HQ stubs are the same so I cant imagine them being a problem.
You can buy blank HQ rotors and have them drilled to suit early stud pattern which is the way I would go - HQ brakes are miles better than HG
If you use HT discs the HQ calipers won't work.
Why not get some Torana discs and calipers, pretty sure they ( calipers) are the same as HQ and you keep the old stud pattern.
Or 4 cylinder Commodore rotors, but they are getting pretty hard to find nowadays .....
EK JAY
Post by EK JAY »
Trev wrote:If you use HT discs the HQ calipers won't work.
thanks Trev
so what stubs can i use will the discs go on the hq stubs or on the hr stubs and do you meen lh lx torana or lc lj
EK JAY SINCE 1990
Not sure if the Q stubs work with the Torana discs (there is a slight difference), I used the whole setup from the Torana LH.
EK JAY
Post by EK JAY »
Trev wrote:Not sure if the Q stubs work with the Torana discs (there is a slight difference), I used the whole setup from the Torana LH.
:smile2: Trev did you use the lh steering arms or HR HQ
and are lx the same disc and calipers /stubs as lh
EK JAY SINCE 1990
Wouldn't think LX would be too different to LH, I don't know I only used the one set.
I used the HR steering arms.
usually torana stubs will make it difficult to wheel align different camber angle on the stubs and i'm pretty sure if you get ones off a torana that had radial tuned suspension it's even worse
EK JAY
Post by EK JAY »
:? What about a combo of hq stubs ht rotors and torana calipers
would this work :?:
EK JAY SINCE 1990
