brakes on rear of the stubs to clear front rack ?
I'm going to be fitting a new cross member with vt brakes and stubtech stubs and front rack . Can I swap the stubs to position the brake callipers on the back of the cross member to clear the steering arms.. Pretty sure it will work but does this mess up braking or weight transfer on braking . . .
Re: brakes on rear of the stubs to clear front rack ?
Hey mate ........I have got a hr frontend with standard caliphers and hr discs on my FJ Ute ...I have a torana front mounted rack and the stubs switched from right to left with the caliphers rear mounted ...no problem ..............Fingers
Hey fingers cheers for your insight ! vt callipers are huge so I think its the only way to actually fit them up . I fitted one of the stubs up and put it on the wrong side which gave me the idea
