336 diff gear in stock ek manual ?
goldcoastr
Post by goldcoastr »
Hi I have a original stock ek and the diff is on its way out
Been searching for a while for the stock 3:88 ratio centre good condition with no luck
Found a Complete banjo diff with reconditioned centre spine & piñon but its ratio 336
Please can confirm is this suited to my stock ek engine and manual 3 speed
I don't actually drive the car much we just want to replace it as mine is very noise at moment
It's the only diff I've found locally most around aust won't post ones that will can't confirm if it runs smooth or not
fb delivery
Re: 336 diff gear in stock ek manual ?
Post by fb delivery »
i have a 3.89 centre $70
Pick up only Toowoomba
goldcoastr
fb delivery wrote:i have a 3.89 centre $70
Do u know if it was good running order before removed if so keen I can come get it this weekend
