What's the Diff? HR/HD
trebla
Post by trebla »
Hi folks! Merry Xmas and all that!
This is my first time on, however I have spent the last couple of weeks trying to educate myself on the right Diff for my EK Wagon that currently has HR Disc front end and Ek Drum rear end.
I have read many say the simplest and effective diff upgrade based on my setup is to change to HR diff.
Question 1. Is the HD & HR diff essentialy the same? I understand the HD uses leaf spring mount that should be compitable with EK without modification, however from what I understand/read the HR mounts differently
Q 2. Can I use a HD instead of HR diff> ( diff ratio is good, Auto adjust brakes, may need to upgrade slave cylinders & pads to disk fron end pecs).
Q3. Can you upgrade HD brake cylinders & pads to HR disk front end spec?
I have tried to learn as much as possible from previouseosts, however I notice that there is no mention of HD diffs. I thought they were pretty much the same.
Appreciate any help on clearing these points up from anyone in the know.
