6 inch x 13 inch Torana rims
fb cruisin
Post by fb cruisin »
Hi guys, will 6 x 13 factory Torana rims fit my FB, I couldn't find anything while searching the older posts if they would scrub or not ?
Cheers Rob
______________
living the dream.
Re: 6 inch x 13 inch Torana rims
i think they do hit king pins tie rod ends but maybe LC/LJ 5" rims are ok, i could be completely wrong :roll: i have a car at home with king pin front and i have a torana rim i could stick it on and check, if no one else has a definate answer, but can't do it till monday as i'm away from home
fb cruisin
Thanks Mick, I'll check the tie rod clearance myself later, not sure what Torana rims these are.
But I think the inside offset may be the same as my original rims, not 100 percent sure though.
Cheers Rob
______________
living the dream.
