2.78 ratio opinions
PAYNEY05
2.78 ratio opinions
Post by PAYNEY05 »
Hi Guys,
I have to change the diff as the 3.36 has called it quits. To get the car back on the road i have a 2.78 to put in.
Can anyone tell me the good and bad about using this ratio? I am running a 138 RED motor(stock) with HR 3 speed gearbox. Wheels are 15 inch.
Most of the driving i do is freeway or not too hilly,
Thanks,
Payney
choppedfan
Re: 2.78 ratio opinions
Post by choppedfan »
PAYNEY05 wrote:Hi Guys,
Thanks,
Payney
You'll end up pulling it back out, it will make car too sluggish. :thumbsdown: :thumbsdown: :thumbsdown:
Save yourself the hassle and wait for another 3.36
Mick 8)
choppedfan
Use this gear/speed calculator Payney and you'll be able to see what the "performance "will be like, even the profile and width of your 15" tyres will affect the outcome :wink:
http://www.kabamus.com/garage/gears.html
Mick 8)
yeah i think it will end up being a problem could be ok once up to speed on the freeway but you'll probly find you'll feel the slightest hill
muza
Post by muza »
choppedfan wrote:Use this gear/speed calculator Payney and you'll be able to see what the "performance "will be like, even the profile and width of your 15" tyres will affect the outcome :wink:
Mick 8)
Thats a ripper!!
Stock as a rock
Not so stock
A pretty hefty challenge for a red 138 - not so bad if you're running an auto.... but a manua - and especially without synchro on 1st.... hmmmm... you'll struggle - and, believe it or not - you'll probably use more fuel.... revs will be lower - but the load on your engine for most of the time will be with the power valve open....
You might have got away with it with a HG onwards 3 speed - with synchro on 1st and a lower 2nd gear.... but if you had that - you'd have to open up the transmission tunnel - why then wouldn't you fit a 4 speed or a Jap box with overdrive.......
Drop back to 3:36 and you'll enjoy good economy, reasonable power - and avoid a lot of grief.... and won't need any engineering....
Just for those who do not know - be very careful when playing with diffs..... if you are running the early red diffs - or the grey - you'll need the "coarse spline" axles..... some of the latter diffs are "fine splined"..... one won't go into the other.....
