Brake fluid
Aussy Edo
Brake fluid
Post by Aussy Edo »
Hi People,
Whats the best brake fluid to run for the EK Drums?
cheerz
Edo
One Day Hopefully!!
Re: Brake fluid
"WOOFTO stopomatic 4000" is the preferred fluid for these old girls , but if you cant find any of that , try normal brake fluid , not silicon based unless you are changing all your seals etc to suit .
MeFB
Re: Brake fluid
Post by MeFB »
Use DOT 3, 4 or 5.1 because they are glycol based and compatible with the rubber components in your brake system. DOT 3 is fine, and the only difference as you go up to 4 or 5.1 is that the boiling point increases (as does the price).
AVOID DOT 5 :shock: DOT 5 is Silicon based and your rubber bits will immediately swell-up and become bloated and squishy, like a fat woman eating donuts.
:arrow: :D
Alan
Aussy Edo
Re: Brake fluid
Post by Aussy Edo »
Thanx Blacky,couldnt find any of your stopomatic 4000 at Superpov :ewink:
Cheerz Allan,i have been using Dot 3 for years but thought there might be something better out there.i was under the impression that anything above Dot 3
was for newer brake systems.
cheerz
Edo
One Day Hopefully!!
