door belts
door belts
does anyone know or have any tips to fitting door belts. because of the flip and quarter windows you have to put the glass in first,i think. then try to" roll" the door belts in with the window rolled down and try not to scratch the paint.
any ideas or suggestions on a better way, because without them the doors fill up with water
BUILT NOT BOUGHT
Re: door belts
I put them in before I put the glass in, gives you more room.
If you don't want your doors to fill up with water just make sure the drain holes are not blocked at the bottom of the doors
